[mapguide-users] Difference between MG Open Source and MG Enterprise2007 for layer point from coordinates Lat Lon
alba a.penitente at gepaspa.com
Fri May 9 12:25:30 EDT 2008
Hi all,
I must to create a layer of point from database with coordinates Lat Lon
I have execute:
Create a datasource.
Create a layer with the datasource.
Create a map.
Select the coordinate system.
Specify the center coordinate manually.
Add the layer.
Press refresh.
All this is true for Map Guide Open Source, but it not true for Map Guide
Enterprise, Why?
The layers of points in MG Enterprise are not visible, it can  be the
problem of System coordinates?
Tanks Alba
View this message in context: http://www.nabble.com/Difference-between-MG-Open-Source-and-MG-Enterprise2007-for-layer-point-from-coordinates-Lat-Lon-tp17151571p17151571.html
