[mapguide-users] Difference between MG Open Source and MG Enterprise2007 for layer point from coordinates Lat Lon
Francisco J Rojas D francisco.rojas at dasoft.com.mx
Sat May 10 19:40:03 EDT 2008
alba wrote:
> Hi all,
> I must to create a layer of point from database with coordinates Lat Lon
> I have execute:
> Create a datasource.
> Create a layer with the datasource.
> Create a map.
> Select the coordinate system.
> Specify the center coordinate manually.
> Add the layer.
> Press refresh.
> All this is true for Map Guide Open Source, but it not true for Map Guide
> Enterprise, Why?
> The layers of points in MG Enterprise are not visible, it can  be the
> problem of System coordinates?
> Tanks Alba
View this message in context: http://www.nabble.com/Difference-between-MG-Open-Source-and-MG-Enterprise2007-for-layer-point-from-coordinates-Lat-Lon-tp17151571p17168626.html
