[mapguide-users] DevGuide samples src change
PLohr
pmlpml001 at yahoo.com
Mon May 12 04:47:15 EDT 2008
Does 'mapguide' still need to be changed to 'mapguide2008' at v2.0.0?
Main.php will not display on my server - wondering if this could be why. As
it is in the original download, main.php still does not use 'mapguide2008'.
Thank you for any help.
Jim O'Leary wrote:
> The devguide samples (analyzing features, custom output, etc) now show
> "cannot display the page" in MGE 2008. That is because the references to
> aliases in the httpd.conf file have all been changed from "mapguide" to
> "mapguide2008".
> To fix this, you have to go to all of the main.php files in the devguide,
> as well as ajax.php in the working_with_feature_data folder, and look for
> the line that says
> <frame
> src="/mapguide/mapviewerajax/
> ...and change it to
> <frame
> src="/mapguide2008/mapviewerajax/
> You shouldn't change the aliases in httpd.conf. It could break something
> else down the line.
View this message in context: http://www.nabble.com/DevGuide-samples-src-change-tp11821844p17183555.html
