[mapguide-users] Fusion - feature hyperlink target?
Mike Adair madair at dmsolutions.ca
Mon May 12 15:56:47 EDT 2008
The Maptip widget does support a <Target> element in it's Extension
element.  The logic that it is currently using is:
- if there is a TaskPane widget with the ID of the target, it will be
directed there, else
- if there is DOM element with the ID of Target, set it's source to the
hyperlink URL (for IFrames), else
- open a new window with name of the Target.
There currently isn't anything similar supported for the CTRL-Click
functionality.
Mike
Andy Morsell wrote:
> Hi,
> Is there a way to specify the feature object hyperlink target frame or
> window in Fusion?  I'm not seeing it.  I see the <Target> nodes for
> things like toolbarMeasure and so on, but nothing for the map itself.
> Thanks,
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> _http://www.SpatialGIS.com_
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
