[mapguide-users] Fusion - feature hyperlink target?
Andy Morsell amorsell at spatialgis.com
Mon May 12 17:03:08 EDT 2008
Thanks Mike.  That was exactly what I was looking for.  I am now able to
target a frame within an application that I'm wrapping around a Fusion
flexible layout.
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mike Adair
Sent: Monday, May 12, 2008 12:57 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Fusion - feature hyperlink target?
The Maptip widget does support a <Target> element in it's Extension element.
The logic that it is currently using is:
- if there is a TaskPane widget with the ID of the target, it will be
directed there, else
- if there is DOM element with the ID of Target, set it's source to the
hyperlink URL (for IFrames), else
- open a new window with name of the Target.
There currently isn't anything similar supported for the CTRL-Click
functionality.
Mike
Andy Morsell wrote:
> Hi,
> Is there a way to specify the feature object hyperlink target frame or
> window in Fusion?  I'm not seeing it.  I see the <Target> nodes for
> things like toolbarMeasure and so on, but nothing for the map itself.
> Thanks,
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> _http://www.SpatialGIS.com_
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
