[mapguide-users] Not correct work Tomcat
PLohr pmlpml001 at yahoo.com
Tue May 13 08:21:24 EDT 2008
Yes, Zac, JAVA_HOME was set prior to installation and I did use
--with-tomcat.
zspitzer wrote:
> did you set the java_home environment variable and use --with-tomcat?
> On Mon, May 12, 2008 at 8:13 PM, PLohr <pmlpml001 at yahoo.com> wrote:
>> I am using v2.0.0 with the build_apt.sh to setup Apache, PHP, and tomcat.
>> Using Fedora Core 4 with gcc-4.1.1. The file 'MapGuideAPI.jar' is missing
>> at
>> /usr/local/mapguideopensource/webserverextensions/www/WEB-INF/lib/. I
>> discovered this when I realized that http://localhost:8080 returns a
>> 'connection refused' error. In an attempt to correct this, I did a make
>> clean against .../LinuxApt/httpd-2.2.4 and .../LinuxApt/php-5.2.5 then I
>> ran
>> ./build_apt.sh again. Tomcat nor Apache had makefiles so there was no
>> obvious place to make clean for either of them. Even after this
>> reinstall,
>> MapGuideAPI.jar is still missing.
>> BTW, mapguide.xml was also missing at
>> /usr/local/mapguideopensource/webserverextensions/tomcat/conf/Catalina/localhost/.
>> The folders Catalina and localhost did not exist - I had to create them.
>> I
>> found this file in my LinuxApt folder and copied it to the location
>> previously mentioned. This did not correct the connection refused error.
>> Thank you for your help.
>> Alain Lebatard wrote:
>>> Hi,
>>> http://localhost:8008/mapguide/mapviewerajax/bufferui.jsp is not a valid
>>> URL. /mapguide/mapviewerajax does not represent a folder, but represent
>>> the AJAX viewer main script. If you look in the httpd.conf file of
>>> Apache bundled with MapGuide, you should see this line:
>>>   Redirect /mapguide/mapviewerajax/
>>> http://<YourHostAddress>/mapguide/mapviewerjava/ajaxviewer.jsp
>>> So when you invoke
>>> http://localhost:8008/mapguide/mapviewerajax/bufferui.jsp, you are
>>> actually invoking
>>> http://localhost:8008/mapguide/mapviewerjava/ajaxviewer.jsp/bufferui.jsp
>>> which is not valid.
>>> Your first call http://localhost:8008/mapguide/mapviewerjava/fake.jsp
>>> was the correct one. If you get a 404 error, it's certainly because
>>> there is no file fake.jsp in
>>> /usr/local/mapguideopensource/webserverextensions/www/mapviewerjava
>>> The compilation errors are probably occurring because the jar file that
>>> contains the API classes (such as MgException) could not be loaded. Make
>>> sure that there is file named MapGuideApi.jar in the folder
>>> /usr/local/mapguideopensource/webserverextensions/www/WEB-INF/lib   If
>>> the file is not there then this is a build issue.
>>> Alain
>>> -----Original Message-----
>>> From: Safonov Alexey [mailto:alex-saf at archit.vrn.ru]
>>> Sent: Wednesday, April 12, 2006 10:15 AM
>>> To: users at mapguide.osgeo.org
>>> Subject: [mapguide-users] Not correct work Tomcat
>>> Dear colleagues!
>>> I have collected mapguide-1.0.0 on a platform linux. Except for most
>>> mapguide I have established LinuxApt with Tomcat. At testing it was
>>> found
>>> out, that on inquiry
>>> http://localhost:8008/mapguide/mapviewerjava/bufferui.jsp the answer
>>> turns
>>> out:
>>> HTTP Status 500 -
>>> type Exception report
>>> message
>>> description The server encountered an internal error () that prevented
>>> it
>>> from fulfilling this request.
>>> exception
>>> org.apache.jasper.JasperException: Unable to compile class for JSP
>>> An error occurred at line: 25 in the jsp file: /mapviewerjava/common.jsp
>>> Generated servlet error:
>>> MgException cannot be resolved to a type
>>> MapGuideJavaApi cannot be resolved
>>> An error occurred at line: 34 in the jsp file:
>>> MgLocalizer cannot be resolved
>>> Though the inquiry http://localhost:8008/mapguide/mapviewerjava/fake.jsp
>>> gives out " 404 error ", as well as is written in a management. The
>>> inquiry
>>> http://localhost:8008/mapguide/mapviewerajax/bufferui.jsp is not carried
>>> out
>>> at all as the catalogue
>>> /usr/local/mapguideopensource/webserverextensions/www/mapviewerajax does
>>> not
>>> exist at all.
>>> How to me to achieve correct work Tomcat?
>>> I use the distributive Linux Fedore Core 4 with the kernel
>>> 2.6.15-1.1833-FC4 and gcc-4.0.2-8.fc4.
>>> Please, help me in solving this problem.
>>> Best regards,
>>> Safonov Alexey
>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
>> View this message in context:
>> http://www.nabble.com/Not-correct-work-Tomcat-tp3885877p17184666.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
View this message in context: http://www.nabble.com/Not-correct-work-Tomcat-tp3885877p17207115.html
