[mapguide-users] Not correct work Tomcat
Zac Spitzer
zac.spitzer at gmail.com
Mon May 12 06:37:33 EDT 2008
did you set the java_home environment variable and use --with-tomcat?
On Mon, May 12, 2008 at 8:13 PM, PLohr <pmlpml001 at yahoo.com> wrote:
> I am using v2.0.0 with the build_apt.sh to setup Apache, PHP, and tomcat.
> Using Fedora Core 4 with gcc-4.1.1. The file 'MapGuideAPI.jar' is missing at
> /usr/local/mapguideopensource/webserverextensions/www/WEB-INF/lib/. I
> discovered this when I realized that http://localhost:8080 returns a
> 'connection refused' error. In an attempt to correct this, I did a make
> clean against .../LinuxApt/httpd-2.2.4 and .../LinuxApt/php-5.2.5 then I ran
> ./build_apt.sh again. Tomcat nor Apache had makefiles so there was no
> obvious place to make clean for either of them. Even after this reinstall,
> MapGuideAPI.jar is still missing.
> BTW, mapguide.xml was also missing at
> /usr/local/mapguideopensource/webserverextensions/tomcat/conf/Catalina/localhost/.
> The folders Catalina and localhost did not exist - I had to create them. I
> found this file in my LinuxApt folder and copied it to the location
> previously mentioned. This did not correct the connection refused error.
> Thank you for your help.
> Alain Lebatard wrote:
>> Hi,
>> http://localhost:8008/mapguide/mapviewerajax/bufferui.jsp is not a valid
>> URL. /mapguide/mapviewerajax does not represent a folder, but represent
>> the AJAX viewer main script. If you look in the httpd.conf file of
>> Apache bundled with MapGuide, you should see this line:
>> Redirect /mapguide/mapviewerajax/
>> http://<YourHostAddress>/mapguide/mapviewerjava/ajaxviewer.jsp
>> So when you invoke
>> http://localhost:8008/mapguide/mapviewerajax/bufferui.jsp, you are
>> actually invoking
>> http://localhost:8008/mapguide/mapviewerjava/ajaxviewer.jsp/bufferui.jsp
>> which is not valid.
>> Your first call http://localhost:8008/mapguide/mapviewerjava/fake.jsp
>> was the correct one. If you get a 404 error, it's certainly because
>> there is no file fake.jsp in
>> /usr/local/mapguideopensource/webserverextensions/www/mapviewerjava
>> The compilation errors are probably occurring because the jar file that
>> contains the API classes (such as MgException) could not be loaded. Make
>> sure that there is file named MapGuideApi.jar in the folder
>> /usr/local/mapguideopensource/webserverextensions/www/WEB-INF/lib If
>> the file is not there then this is a build issue.
>> Alain
>> -----Original Message-----
>> From: Safonov Alexey [mailto:alex-saf at archit.vrn.ru]
>> Sent: Wednesday, April 12, 2006 10:15 AM
>> To: users at mapguide.osgeo.org
>> Subject: [mapguide-users] Not correct work Tomcat
>> Dear colleagues!
>> I have collected mapguide-1.0.0 on a platform linux. Except for most
>> mapguide I have established LinuxApt with Tomcat. At testing it was
>> found
>> out, that on inquiry
>> http://localhost:8008/mapguide/mapviewerjava/bufferui.jsp the answer
>> turns
>> out:
>> HTTP Status 500 -
>> type Exception report
>> message
>> description The server encountered an internal error () that prevented
>> it
>> from fulfilling this request.
>> exception
>> org.apache.jasper.JasperException: Unable to compile class for JSP
>> An error occurred at line: 25 in the jsp file: /mapviewerjava/common.jsp
>> Generated servlet error:
>> MgException cannot be resolved to a type
>> MapGuideJavaApi cannot be resolved
>> An error occurred at line: 34 in the jsp file:
>> MgLocalizer cannot be resolved
>> Though the inquiry http://localhost:8008/mapguide/mapviewerjava/fake.jsp
>> gives out " 404 error ", as well as is written in a management. The
>> inquiry
>> http://localhost:8008/mapguide/mapviewerajax/bufferui.jsp is not carried
>> out
>> at all as the catalogue
>> /usr/local/mapguideopensource/webserverextensions/www/mapviewerajax does
>> not
>> exist at all.
>> How to me to achieve correct work Tomcat?
>> I use the distributive Linux Fedore Core 4 with the kernel
>> 2.6.15-1.1833-FC4 and gcc-4.0.2-8.fc4.
>> Please, help me in solving this problem.
>> Best regards,
>> Safonov Alexey
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
> View this message in context: http://www.nabble.com/Not-correct-work-Tomcat-tp3885877p17184666.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
