[mapguide-users] Not correct work Tomcat
PLohr pmlpml001 at yahoo.com
Mon May 12 06:13:32 EDT 2008
I am using v2.0.0 with the build_apt.sh to setup Apache, PHP, and tomcat.
Using Fedora Core 4 with gcc-4.1.1. The file 'MapGuideAPI.jar' is missing at
/usr/local/mapguideopensource/webserverextensions/www/WEB-INF/lib/. I
discovered this when I realized that http://localhost:8080 returns a
'connection refused' error. In an attempt to correct this, I did a make
clean against .../LinuxApt/httpd-2.2.4 and .../LinuxApt/php-5.2.5 then I ran
./build_apt.sh again. Tomcat nor Apache had makefiles so there was no
obvious place to make clean for either of them. Even after this reinstall,
MapGuideAPI.jar is still missing.
BTW, mapguide.xml was also missing at
/usr/local/mapguideopensource/webserverextensions/tomcat/conf/Catalina/localhost/.
The folders Catalina and localhost did not exist - I had to create them. I
found this file in my LinuxApt folder and copied it to the location
previously mentioned. This did not correct the connection refused error.
Thank you for your help.
Alain Lebatard wrote:
> Hi,
> http://localhost:8008/mapguide/mapviewerajax/bufferui.jsp is not a valid
> URL. /mapguide/mapviewerajax does not represent a folder, but represent
> the AJAX viewer main script. If you look in the httpd.conf file of
> Apache bundled with MapGuide, you should see this line:
>   Redirect /mapguide/mapviewerajax/
> http://<YourHostAddress>/mapguide/mapviewerjava/ajaxviewer.jsp
> So when you invoke
> http://localhost:8008/mapguide/mapviewerajax/bufferui.jsp, you are
> actually invoking
> http://localhost:8008/mapguide/mapviewerjava/ajaxviewer.jsp/bufferui.jsp
> which is not valid.
> Your first call http://localhost:8008/mapguide/mapviewerjava/fake.jsp
> was the correct one. If you get a 404 error, it's certainly because
> there is no file fake.jsp in
> /usr/local/mapguideopensource/webserverextensions/www/mapviewerjava
> The compilation errors are probably occurring because the jar file that
> contains the API classes (such as MgException) could not be loaded. Make
> sure that there is file named MapGuideApi.jar in the folder
> /usr/local/mapguideopensource/webserverextensions/www/WEB-INF/lib   If
> the file is not there then this is a build issue.
> Alain
> -----Original Message-----
> From: Safonov Alexey [mailto:alex-saf at archit.vrn.ru]
> Sent: Wednesday, April 12, 2006 10:15 AM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] Not correct work Tomcat
> Dear colleagues!
> I have collected mapguide-1.0.0 on a platform linux. Except for most
> mapguide I have established LinuxApt with Tomcat. At testing it was
> found
> out, that on inquiry
> http://localhost:8008/mapguide/mapviewerjava/bufferui.jsp the answer
> turns
> out:
> HTTP Status 500 -
> type Exception report
> message
> description The server encountered an internal error () that prevented
> it
> from fulfilling this request.
> exception
> org.apache.jasper.JasperException: Unable to compile class for JSP
> An error occurred at line: 25 in the jsp file: /mapviewerjava/common.jsp
> Generated servlet error:
> MgException cannot be resolved to a type
> MapGuideJavaApi cannot be resolved
> An error occurred at line: 34 in the jsp file:
> MgLocalizer cannot be resolved
> Though the inquiry http://localhost:8008/mapguide/mapviewerjava/fake.jsp
> gives out " 404 error ", as well as is written in a management. The
> inquiry
> http://localhost:8008/mapguide/mapviewerajax/bufferui.jsp is not carried
> out
> at all as the catalogue
> /usr/local/mapguideopensource/webserverextensions/www/mapviewerajax does
> not
> exist at all.
> How to me to achieve correct work Tomcat?
> I use the distributive Linux Fedore Core 4 with the kernel
> 2.6.15-1.1833-FC4 and gcc-4.0.2-8.fc4.
> Please, help me in solving this problem.
> Best regards,
> Safonov Alexey
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context: http://www.nabble.com/Not-correct-work-Tomcat-tp3885877p17184666.html
