[mapguide-users] Fusion - feature hyperlink target?
Andy Morsell
amorsell at spatialgis.com
Tue May 13 12:48:15 EDT 2008
Yes, that makes sense judging from the URL from Studio. It points the
ApplicationDefinition to a repository definition instead of on the
filesystem. This was what was confusing me, I was expecting the
/slate/ApplicationDefinition.xml to supercede all but instead MapGuide is
only using the index.html in the /slate/ folder to assemble the Fusion parts
and pieces and then using it's own ApplicationDefinition from the
repository.
http://192.168.1.109:8008/mapguide/fusion/templates/mapguide/slate/index.htm
l?ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboygan%2fFlexibleLayout
s%2fSlate.ApplicationDefinition
Whereas this will use the AppDef on the filesystem
l?
So, it looks like my objective of having a master ApplicationDefinition on
the filesystem that I can globally tweak as needed for that application will
not work well when using Studio flexible web layouts. I really wanted the
template read every time at run-time by the Studio flexible layout, but
that's not how it works. Rather, I will use the file system definition
exclusively where I can accomplish what I need. It still looks like I ran
into a bug or two with Studio inheriting the parent ApplicationDefinition
template definitions when first defining a layout so I will log those issues
with Autodesk.
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul Spencer
Sent: Tuesday, May 13, 2008 8:54 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Fusion - feature hyperlink target?
No, that's right - when you use Studio it is using an AppDef stored inside
the MapGuide repository, not the one on the file system. When you launch it
from Studio, it appends something to the URL to get it to use the AppDef
from the repository.
Cheers
Paul
On 13-May-08, at 10:56 AM, Jason Birch wrote:
> Andy,
> I don't believe that MapGuide Studio uses the filesystem-level AppDef
> at all. A flexible web layout is basically just an
> ApplicationDefinition that has been added to the MapGuide repository,
> so you should be able to use the MapAgent API to upload your tweaked
> version.
> I could be absolutely wrong on this of course; I'm not using Studio
> 2009
> yet.
> Jason
> From: Andy Morsell
> Subject: RE: [mapguide-users] Fusion - feature hyperlink target?
> To start, I copied and renamed the Slate template and edited it's
> ApplicationDefinition.xml file. In there, I changed the maptip target
> from the default of "NewWindow" to my target frame name.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
