[mapguide-users] Fusion - feature hyperlink target?
Paul Spencer
pagameba at gmail.com
Tue May 13 11:54:24 EDT 2008
No, that's right - when you use Studio it is using an AppDef stored
inside the MapGuide repository, not the one on the file system. When
you launch it from Studio, it appends something to the URL to get it
to use the AppDef from the repository.
Cheers
Paul
On 13-May-08, at 10:56 AM, Jason Birch wrote:
> Andy,
> I don't believe that MapGuide Studio uses the filesystem-level
> AppDef at
> all. A flexible web layout is basically just an ApplicationDefinition
> that has been added to the MapGuide repository, so you should be
> able to
> use the MapAgent API to upload your tweaked version.
> I could be absolutely wrong on this of course; I'm not using Studio
> 2009
> yet.
> Jason
> -----Original Message-----
> From: Andy Morsell
> Subject: RE: [mapguide-users] Fusion - feature hyperlink target?
> To start, I copied and renamed the Slate template and edited it's
> ApplicationDefinition.xml file. In there, I changed the maptip
> target from the default of "NewWindow" to my target frame name.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
