[mapguide-users] Fusion - feature hyperlink target?
Jason Birch
Jason.Birch at nanaimo.ca
Tue May 13 10:56:59 EDT 2008
Andy,
I don't believe that MapGuide Studio uses the filesystem-level AppDef at
all. A flexible web layout is basically just an ApplicationDefinition
that has been added to the MapGuide repository, so you should be able to
use the MapAgent API to upload your tweaked version.
I could be absolutely wrong on this of course; I'm not using Studio 2009
yet.
Jason
-----Original Message-----
Subject: RE: [mapguide-users] Fusion - feature hyperlink target?
To start, I copied and renamed the Slate template and edited it's
ApplicationDefinition.xml file. In there, I changed the maptip
target from the default of "NewWindow" to my target frame name.
