[mapguide-users] Fusion - feature hyperlink target?
Mike Adair
madair at dmsolutions.ca
Tue May 13 09:49:45 EDT 2008
Andy,
All widgets have (or should have) reasonable default values that will be
used if they aren't specified in the AppDef. Have a look at the widget
documentation http://trac.osgeo.org/fusion/wiki/Widgets and for the
Maptip in particular at http://trac.osgeo.org/fusion/wiki/Widgets/Maptip.
If you are setting something in the AppDef that isn't getting picked up
by Fusion, then that is probably a bug and filing a ticket would be the
best way to get it fixed.
It is quite possible that targeting a Frame element in IE is buggy and
again bug reports through the Fusion Trac are appreciated.
Mike
Andy Morsell wrote:
> Mike,
> I'm seeing something strange with this and hope that you can help. I have
> created a new template definition for this application. To start, I copied
> and renamed the Slate template and edited it's ApplicationDefinition.xml
> file. In there, I changed the maptip target from the default of "NewWindow"
> to my target frame name. Now, in Autodesk Studio, I can choose my new
> template as the basis for a flexible web layout. When I look at the maptip
> target parameter in the GUI or in the XML, it shows the Target as
> "MaptipWindow". So, where is it picking that up from? It also shows a
> couple of other elements, such as tolerance and delay that aren't present in
> the template's ApplicationDefinition.xml file. Again, where would it be
> inheriting those from? My assumption was that if I edited the
> ApplicationDefinition.xml file, that the components for my layout would be
> inherited from there but that appears to not be the case.
> Another problem I'm seeing is that the correct frame is targeted in Firefox,
> but not in Internet Explorer. In IE, a blank window is still opened
> indicating that the code is not finding the correct object.
> Andy
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mike Adair
> Sent: Monday, May 12, 2008 12:57 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Fusion - feature hyperlink target?
> The Maptip widget does support a <Target> element in it's Extension element.
> The logic that it is currently using is:
> - if there is a TaskPane widget with the ID of the target, it will be
> directed there, else
> - if there is DOM element with the ID of Target, set it's source to the
> hyperlink URL (for IFrames), else
> - open a new window with name of the Target.
> There currently isn't anything similar supported for the CTRL-Click
> functionality.
> Mike
> Andy Morsell wrote:
>> Hi,
>> Is there a way to specify the feature object hyperlink target frame or
>> window in Fusion? I'm not seeing it. I see the <Target> nodes for
>> things like toolbarMeasure and so on, but nothing for the map itself.
>> Thanks,
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> _http://www.SpatialGIS.com_
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
