[mapguide-users] New UpdateFeatures problem
Klaus Lehtonen
kle at vianova.fi
Thu May 15 04:53:25 EDT 2008
There have been similar problems with MG 2.0 using .NET in this list before,
but the things mentioned in those posts did not solve my problem. I am
trying to add many features to a database using many UpdateFeatures calls.
Usually if i try to add one or two features everything works fine. When
adding ten or more features only about 10% - 90% of the features go to the
database and the rest give MgResourceBusyExceptions saying to try later. I
also tried to add a delay when getting the exception and try again later,
but that does not seem to work. This is pretty odd behavior as the result
seems to be quite random.
View this message in context: http://www.nabble.com/New-UpdateFeatures-problem-tp17248351p17248351.html
