[mapguide-users] New UpdateFeatures problem
Zac Spitzer
zac.spitzer at gmail.com
Thu May 15 05:06:58 EDT 2008
which fdo provider (database) are you using?
On Thu, May 15, 2008 at 6:53 PM, Klaus Lehtonen <kle at vianova.fi> wrote:
> There have been similar problems with MG 2.0 using .NET in this list before,
> but the things mentioned in those posts did not solve my problem. I am
> trying to add many features to a database using many UpdateFeatures calls.
> Usually if i try to add one or two features everything works fine. When
> adding ten or more features only about 10% - 90% of the features go to the
> database and the rest give MgResourceBusyExceptions saying to try later. I
> also tried to add a delay when getting the exception and try again later,
> but that does not seem to work. This is pretty odd behavior as the result
> seems to be quite random.
> View this message in context: http://www.nabble.com/New-UpdateFeatures-problem-tp17248351p17248351.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
