[mapguide-users] MrSID not working with 2.0?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri May 16 08:52:19 EDT 2008
I've tried a bunch of different ways and image types (so it's a bit hard
to explain) - I think it'd be easier if someone posts a step by step
guide.....given the number of people that have problems with this, I
really think that we need a revised (and much more specific) page / set
of instructions that gives exact details on how to set up and use the
GDAL plugins......I'm clearly not alone - there are lots of us that seem
to be missing some critical step. I know that the lack of the autodesk
provider was a big reason why I stuck with MGOS 1.x for so long....I'd
read about so many people having problems getting the gdal to work, I
was afraid that I'd switch and lose my rasters...which has happened.
Andrew
Berdel, Brian wrote:
> Andrew,
> I was able to get them working and they a have been relatively stable,
> but it is only on a development machine.  Can you outline the steps
> you took, and maybe I can see if you missed a step or if I can make a
> suggestion.
> Brian
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Friday, May 16, 2008 8:35 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] MrSID not working with 2.0?
> Just out of curiosity, is there a way to use the old raster provider
> (from MGOS 1.x) under 2.x? I've tried copying the dll and modifying
> the providers.xml, but I think that I must have to register the dll in
> windows somehow, because I got an invalid entry point msg (on the
> server) when I tried to use it. Why did that provider get removed from
> the 2.x release anyway? I know that it was an Autodesk provider and
> all....did they just "lend" it to the 1.x open source release, under
> the condition that it be removed for the 2.x branch?
> Andrew
> Dave Wilson wrote:
> Just something to eliminate but often people in their feature sources depending on the raster format are not ensuring a coordinate system is defined on the feature source. This is important and is required, it's possible this could cause some problems.
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org <mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of isca
> Sent: Thursday, May 15, 2008 1:06 PM
> To: mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> Subject: Re: [mapguide-users] MrSID not working with 2.0?
> I am able to show MrSid files with MGOS 2.0, but from time to time I get
> server crashes. The log files are indicating something went wrong with
> stylization of the layer, but I could not find any pattern in the crashes.
> Therefore I disabled the raster layers. Looking on the forum there are a lot
> of people encountering similar problems with raster files.
> Rock Beans wrote:
>> That makes me cry a little. Well if I come up with anything I will post
>> back. Any other info from the top dogs would be great!
>> Thanks
>> The Rock
>> On Tue, May 13, 2008 at 1:54 PM, Andrew DeMerchant <
>> andrew.demerchant at gemtec.ca <mailto:andrew.demerchant at gemtec.ca>> wrote:
>>>  No luck here....I've had success with other formats though. I filed a
>>> trac about my mrsid problem a month ago (or so).
>>> Rock Beans wrote:
>>> I followed the directions on the
>>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#FDO3.3.0MapGuide2.0.0 pages.
>>> I
>>> am not getting any to work. I have not tested any other formats yet. Has
>>> anyone had luck with this or is there an update to the GDAL?
>>> The Rock
>>> mapguide-users mailing
>>> listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users <mailto:listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users>
>>>     *Andrew DeMerchant*
>>>  *Computer Technologist*
>>> ph.1-877-2GEMTEC x.163
>>> fax 506-453-9470
>>> *GEMTEC Limited <http://www.gemtec.ca>
>>> *191 Doak Road
>>> Fredericton, NB, Canada
>>>  E3C 2E6
>>> mapguide-users mailing list
> View this message in context: http://www.nabble.com/MrSID-not-working-with-2.0--tp17215741p17260246.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> *Andrew DeMerchant*
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
