[mapguide-users] MrSID not working with 2.0?
Zac Spitzer zac.spitzer at gmail.com
Fri May 16 08:56:25 EDT 2008
have you tried the mapguide 2.0.1 builds mentioned over on mapguide-internals?
i have found them to be much more stable, but i haven't tried any rasters yet...
z
On Fri, May 16, 2008 at 10:52 PM, Andrew DeMerchant
<andrew.demerchant at gemtec.ca> wrote:
> I've tried a bunch of different ways and image types (so it's a bit hard to
> explain) - I think it'd be easier if someone posts a step by step
> guide.....given the number of people that have problems with this, I really
> think that we need a revised (and much more specific) page / set of
> instructions that gives exact details on how to set up and use the GDAL
> plugins......I'm clearly not alone - there are lots of us that seem to be
> missing some critical step. I know that the lack of the autodesk provider
> was a big reason why I stuck with MGOS 1.x for so long....I'd read about so
> many people having problems getting the gdal to work, I was afraid that I'd
> switch and lose my rasters...which has happened.
> Andrew
> Berdel, Brian wrote:
> Andrew,
> I was able to get them working and they a have been relatively stable, but
> it is only on a development machine.  Can you outline the steps you took,
> and maybe I can see if you missed a step or if I can make a suggestion.
> Brian
> ________________________________
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
> DeMerchant
> Sent: Friday, May 16, 2008 8:35 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] MrSID not working with 2.0?
> Just out of curiosity, is there a way to use the old raster provider (from
> MGOS 1.x) under 2.x? I've tried copying the dll and modifying the
> providers.xml, but I think that I must have to register the dll in windows
> somehow, because I got an invalid entry point msg (on the server) when I
> tried to use it. Why did that provider get removed from the 2.x release
> anyway? I know that it was an Autodesk provider and all....did they just
> "lend" it to the 1.x open source release, under the condition that it be
> removed for the 2.x branch?
> Andrew
> Dave Wilson wrote:
> Just something to eliminate but often people in their feature sources
> depending on the raster format are not ensuring a coordinate system is
> defined on the feature source. This is important and is required, it's
> possible this could cause some problems.
> Dave
> -----Original Message-----
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of isca
> Sent: Thursday, May 15, 2008 1:06 PM
> To: mapguide-users at lists.osgeo.org
> I am able to show MrSid files with MGOS 2.0, but from time to time I get
> server crashes. The log files are indicating something went wrong with
> stylization of the layer, but I could not find any pattern in the crashes.
> Therefore I disabled the raster layers. Looking on the forum there are a lot
> of people encountering similar problems with raster files.
> Rock Beans wrote:
> That makes me cry a little. Well if I come up with anything I will post
> back. Any other info from the top dogs would be great!
> Thanks
> The Rock
> On Tue, May 13, 2008 at 1:54 PM, Andrew DeMerchant <
>  No luck here....I've had success with other formats though. I filed a
> trac about my mrsid problem a month ago (or so).
> Rock Beans wrote:
> I followed the directions on the
> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#FDO3.3.0MapGuide2.0.0 pages.
> I
> am not getting any to work. I have not tested any other formats yet. Has
> anyone had luck with this or is there an update to the GDAL?
> The Rock
> mapguide-users mailing
> listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
>     *Andrew DeMerchant*
>  *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> *GEMTEC Limited <http://www.gemtec.ca>
> *191 Doak Road
> Fredericton, NB, Canada
>  E3C 2E6
> mapguide-users mailing list
> http://www.nabble.com/MrSID-not-working-with-2.0--tp17215741p17260246.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> Andrew DeMerchant
> fax 506-453-9470
> GEMTEC Limited
> 191 Doak Road
> E3C 2E6
> Andrew DeMerchant
> fax 506-453-9470
> GEMTEC Limited
> 191 Doak Road
> E3C 2E6
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
