[mapguide-users] MrSID not working with 2.0?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri May 16 08:59:22 EDT 2008
I've never even heard of mapguide-internals (is that another mailing
list?).....but they should use the same gdal plugin, i'd imagine, as I'm
having to use.
Zac Spitzer wrote:
> have you tried the mapguide 2.0.1 builds mentioned over on mapguide-internals?
> i have found them to be much more stable, but i haven't tried any rasters yet...
> z
> On Fri, May 16, 2008 at 10:52 PM, Andrew DeMerchant
> <andrew.demerchant at gemtec.ca> wrote:
>> I've tried a bunch of different ways and image types (so it's a bit hard to
>> explain) - I think it'd be easier if someone posts a step by step
>> guide.....given the number of people that have problems with this, I really
>> think that we need a revised (and much more specific) page / set of
>> instructions that gives exact details on how to set up and use the GDAL
>> plugins......I'm clearly not alone - there are lots of us that seem to be
>> missing some critical step. I know that the lack of the autodesk provider
>> was a big reason why I stuck with MGOS 1.x for so long....I'd read about so
>> many people having problems getting the gdal to work, I was afraid that I'd
>> switch and lose my rasters...which has happened.
>> Andrew
>> Berdel, Brian wrote:
>> Andrew,
>> I was able to get them working and they a have been relatively stable, but
>> it is only on a development machine.  Can you outline the steps you took,
>> and maybe I can see if you missed a step or if I can make a suggestion.
>> Brian
>> ________________________________
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
>> DeMerchant
>> Sent: Friday, May 16, 2008 8:35 AM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] MrSID not working with 2.0?
>> Just out of curiosity, is there a way to use the old raster provider (from
>> MGOS 1.x) under 2.x? I've tried copying the dll and modifying the
>> providers.xml, but I think that I must have to register the dll in windows
>> somehow, because I got an invalid entry point msg (on the server) when I
>> tried to use it. Why did that provider get removed from the 2.x release
>> anyway? I know that it was an Autodesk provider and all....did they just
>> "lend" it to the 1.x open source release, under the condition that it be
>> removed for the 2.x branch?
>> Andrew
>> Dave Wilson wrote:
>> Just something to eliminate but often people in their feature sources
>> depending on the raster format are not ensuring a coordinate system is
>> defined on the feature source. This is important and is required, it's
>> possible this could cause some problems.
>> Dave
>> -----Original Message-----
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of isca
>> Sent: Thursday, May 15, 2008 1:06 PM
>> To: mapguide-users at lists.osgeo.org
>> I am able to show MrSid files with MGOS 2.0, but from time to time I get
>> server crashes. The log files are indicating something went wrong with
>> stylization of the layer, but I could not find any pattern in the crashes.
>> Therefore I disabled the raster layers. Looking on the forum there are a lot
>> of people encountering similar problems with raster files.
>> Rock Beans wrote:
>> That makes me cry a little. Well if I come up with anything I will post
>> back. Any other info from the top dogs would be great!
>> Thanks
>> The Rock
>> On Tue, May 13, 2008 at 1:54 PM, Andrew DeMerchant <
>>  No luck here....I've had success with other formats though. I filed a
>> trac about my mrsid problem a month ago (or so).
>> Rock Beans wrote:
>> I followed the directions on the
>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#FDO3.3.0MapGuide2.0.0 pages.
>> I
>> am not getting any to work. I have not tested any other formats yet. Has
>> anyone had luck with this or is there an update to the GDAL?
>> The Rock
>> mapguide-users mailing
>> listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
>>     *Andrew DeMerchant*
>>  *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> *GEMTEC Limited <http://www.gemtec.ca>
>> *191 Doak Road
>> Fredericton, NB, Canada
>>  E3C 2E6
>> mapguide-users mailing list
>> View this message in context:
>> http://www.nabble.com/MrSID-not-working-with-2.0--tp17215741p17260246.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> Andrew DeMerchant
>> fax 506-453-9470
>> GEMTEC Limited
>> 191 Doak Road
>> E3C 2E6
>> Andrew DeMerchant
>> fax 506-453-9470
>> GEMTEC Limited
>> 191 Doak Road
>> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
