[mapguide-users] MrSID not working with 2.0?
Rock Beans
rockbeans at gmail.com
Fri May 16 11:32:25 EDT 2008
In a raster based feature source there is no where to override a cord system
so can you please explain?
On Thu, May 15, 2008 at 2:24 PM, Dave Wilson <dave.wilson at autodesk.com>
wrote:
> Just something to eliminate but often people in their feature sources
> depending on the raster format are not ensuring a coordinate system is
> defined on the feature source. This is important and is required, it's
> possible this could cause some problems.
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] On Behalf Of isca
> Sent: Thursday, May 15, 2008 1:06 PM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] MrSID not working with 2.0?
> I am able to show MrSid files with MGOS 2.0, but from time to time I get
> server crashes. The log files are indicating something went wrong with
> stylization of the layer, but I could not find any pattern in the crashes.
> Therefore I disabled the raster layers. Looking on the forum there are a
> lot
> of people encountering similar problems with raster files.
> Rock Beans wrote:
> > That makes me cry a little. Well if I come up with anything I will post
> > back. Any other info from the top dogs would be great!
> > Thanks
> > The Rock
> > On Tue, May 13, 2008 at 1:54 PM, Andrew DeMerchant <
> > andrew.demerchant at gemtec.ca> wrote:
> >> No luck here....I've had success with other formats though. I filed a
> >> trac about my mrsid problem a month ago (or so).
> >> Rock Beans wrote:
> >> I followed the directions on the
> >> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#FDO3.3.0MapGuide2.0.0pages.
> >> I
> >> am not getting any to work. I have not tested any other formats yet. Has
> >> anyone had luck with this or is there an update to the GDAL?
> >> The Rock
> >> _______________________________________________
> >> mapguide-users mailing
> >> listmapguide-users at lists.osgeo.orghttp://
> lists.osgeo.org/mailman/listinfo/mapguide-users
> >> *Andrew DeMerchant*
> >> *Computer Technologist*
> >> ph.1-877-2GEMTEC x.163
> >> fax 506-453-9470
> >> *GEMTEC Limited <http://www.gemtec.ca>
> >> *191 Doak Road
> >> Fredericton, NB, Canada
> >> E3C 2E6
> >> mapguide-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/MrSID-not-working-with-2.0--tp17215741p17260246.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080516/eab6d8ce/attachment.html
