[mapguide-users] Please try your operation later as the resource was busy
Mark Pendergraft markp at meadgilman.com
Fri May 16 13:44:13 EDT 2008
I am getting this message too.  I am closing my feature reader and disposing
of it.
The problem happens when the user adds features to one of the feature
sources named "Jobs".  We use our map primarily to track where we have
worked, and users need to be able to add jobs to the map.  Sometimes it
works, other times it harrasses me about the resource being busy.  I would
have to use the library resource because the changes need to show up in
everyones map.
Am i missing something here?  is there a way to possibly check if the
resource is busy and force it to not be?
zspitzer wrote:
> Are you closing your featureReader? show us some more code :)
> Also, you probably want to be using session resources rather than
> library resources
View this message in context: http://www.nabble.com/Please-try-your-operation-later-as-the-resource-was-busy-tp16392736p17280519.html
