[mapguide-users] flexible layout (fusion) and hyperlink in
	attribute
    David Nuell
    nuell at nicholsenvironmental.com
    Thu May 22 11:20:12 EDT 2008
Hi Andy -
I am using "a href="link">click here "
Is this what you are doing in the MySQL database table or are you using just
"http://link"
Thanks in advance!
Andy Morsell wrote:
> I'm using Fusion and 2.0 with hyperlinks with no issues.  Same scenario,
> the
> hyperlinks are read from a field in a MySQL database table.  In my case,
> they are fully qualified with http://.  Maybe that would make a difference
> for some reason?
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of David Nuell
> Sent: Friday, May 16, 2008 7:52 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] flexible layout (fusion) and hyperlink in
> attribute
> Hi listers -
> I have been working with MG Studio 2009 and the flexible layouts and have
> noticed a hyperlink issue.
> I have a series of attributes in a DB that are all something like
> www.something.com click here .  When I load a normal layout with these
> attributes, the properties panel shows the hyperlink 'Click Here' without
> any issues.  When I load the same data into a flexible layout (fusion) the
> hyperlink does not show up... just the actual text  www.something.com
> click
> here
> Anyone have a suggestion as to how to get this to work in the fusion
> layout?
> cheers!
> http://www.nabble.com/flexible-layout-%28fusion%29-and-hyperlink-in-attribut
> e-tp17276635p17276635.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/flexible-layout-%28fusion%29-and-hyperlink-in-attribute-tp17276635p17406608.html
