[mapguide-users] Please try your operation later as the
resource was busy
A H
hizperion at hotmail.com
Wed May 21 00:27:16 EDT 2008
i'm using MGOS1.2 and got the same error while trying to query a recently
updated layer
MgFeatureQueryOptions locQuery = new MgFeatureQueryOptions();
locQuery.SetFilter("ID like '%'");
MgFeatureReader locReader = locLayer.SelectFeatures(locQuery);
MgSelection selection = new MgSelection(map);
selection.AddFeatures(locLayer, locReader, 0);
selectionXml = selection.ToXml();
Please try your operation later as the resource was busy:
Session:98c4f84e-ffff-ffff-8000-00508bbe3169_en_0A0223600AFC0AFB0AFA//Location.FeatureSource
Exception occurred in method
MgServerResourceService.RemoveCachedFdoConnection at line 2234 in file
c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ServerResourceService.cpp
Bruce Dechant wrote:
> Mark,
> The access is similar to a database, except is dependent on what the
> underlying provider supports. In the SDF case I believe this is multiple
> reads and single write is supported.
> Thanks,
> Bruce
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark
> Pendergraft
> Sent: Friday, May 16, 2008 1:03 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Please try your operation later as the
> resource was busy
> I'm a little confused here.
> You make it sound as if only one person can update the library resource
> (in
> this case a .sdf file) at a time. I thought that multiple people could
> interact with the file making changes at the same time more like a
> database.
> I get this error about every other time i try to add a feature to my
> feature
> source. There is a lot of code that could be suspect, i will try to
> isolate
> the error this weekend and if it's not my code i will submit a trac
> ticket.
>> Mark,
>> The error you see below is typically a result of the resource still being
>> used by someone else. However, if a feature reader is not closed and you
>> try to do something with the same resource (update) it can report that it
>> is in use still and therefore busy.
>> Since you are closing your feature reader I suspect the problem is most
>> likely a defect if you are the only one that is using it.
>> What provider is this happening with? Is this easily reproduced?
>> If you could create a track ticket for this and include as much
>> information as possible for someone to investigate the issue that would
>> be
>> great.
>> Thanks,
>> Bruce
>> Pendergraft
>> Sent: Friday, May 16, 2008 11:44 AM
>> Subject: Re: [mapguide-users] Please try your operation later as the
>> resource was busy
>> I am getting this message too. I am closing my feature reader and
>> disposing
>> of it.
>> The problem happens when the user adds features to one of the feature
>> sources named "Jobs". We use our map primarily to track where we have
>> worked, and users need to be able to add jobs to the map. Sometimes it
>> works, other times it harrasses me about the resource being busy. I
>> would
>> have to use the library resource because the changes need to show up in
>> everyones map.
>> Am i missing something here? is there a way to possibly check if the
>> resource is busy and force it to not be?
>> zspitzer wrote:
>>> Are you closing your featureReader? show us some more code :)
>>> Also, you probably want to be using session resources rather than
>>> library resources
>> View this message in context:
>> http://www.nabble.com/Please-try-your-operation-later-as-the-resource-was-busy-tp16392736p17280519.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Please-try-your-operation-later-as-the-resource-was-busy-tp16392736p17282025.html
View this message in context: http://www.nabble.com/Please-try-your-operation-later-as-the-resource-was-busy-tp16392736p17355741.html
