AW: [mapguide-users] Loading dwf without Mapguide Studio
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed May 21 07:16:06 EDT 2008
Interresting.
What is the provider type of the DWF feature source?
Regards, Kenneth Skovhede, GEOGRAF A/S
Stephan HOLLAUS skrev:
> i thought so too, but then I found the dwf File in the Folder
> "C:\Programme\MapGuideOpenSource2.0\Server\Repositories\Library\DataFiles\b70eab7a-ffff-ffff-8000-000c29c577cf"
> on der Mapguideserver. I found no matching sdf data and when the dwf
> is removed, mapguide doesn't display the data anymore, so that I
> believe there is a direct connection. The ohter thing is, that we use
> dwf because the very complex data(linetypes, Symbols..) and I can't
> believe, that this data is converted to sdf
> mfg Stephan Hollaus
> Ingenieur Studio Hollaus
> Tel.:   +43 664 3387158
> Fax.:  +43 664 77 3387159
> www: http://www.hollaus.at <http://www.hollaus.at/>
> Brandströmgasse 10
> 3100 St. Pölten
> V55BCPWP
> *Von:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *Im Auftrag von
> *Kenneth Skovhede, GEOGRAF A/S
> *Gesendet:* Mittwoch, 21. Mai 2008 12:05
> *An:* MapGuide Users Mail List
> *Betreff:* Re: [mapguide-users] Loading dwf without Mapguide Studio
> Not that I know of.
> There are no FDO providers capable of displaying DWF files:
> http://fdo.osgeo.org/OSProviderOverviews.html
> I belive Studio extracts the data from the DWF, and inserts it as SDF
> data in the server (but I have not tried it).
> There exists a DWF toolkit, so you may do this manually:
> http://usa.autodesk.com/adsk/servlet/index?id=823771&siteID=123112
> I'm guessing it will take some time to get it all to work.
> If you can live with Studio only being avalible on the windows
> platform, it is
> possible to call Studio via. .Net and perform the loads without manual
> intervention.
>> Hi
>> Is there a way to load dwf Files without Mapguide Studio?
>> thx
>> mfg Stephan Hollaus
>> Brandströmgasse 10
>> 3100 St. Pölten
>> V55BCPWP
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080521/46029307/attachment.html
