AW: [mapguide-users] Loading dwf without Mapguide Studio
Stephan HOLLAUS
stephan.hollaus at hollaus.at
Wed May 21 06:58:34 EDT 2008
i thought so too, but then I found the dwf File in the Folder "C:\Programme\MapGuideOpenSource2.0\Server\Repositories\Library\DataFiles\b70eab7a-ffff-ffff-8000-000c29c577cf" on der Mapguideserver. I found no matching sdf data and when the dwf is removed, mapguide doesn't display the data anymore, so that I believe there is a direct connection. The ohter thing is, that we use dwf because the very complex data(linetypes, Symbols..) and I can't believe, that this data is converted to sdf
mfg Stephan Hollaus
Ingenieur Studio Hollaus
Tel.: +43 664 3387158
Fax.: +43 664 77 3387159
www: http://www.hollaus.at <http://www.hollaus.at/>
Brandströmgasse 10
3100 St. Pölten
V55BCPWP
Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Kenneth Skovhede, GEOGRAF A/S
Gesendet: Mittwoch, 21. Mai 2008 12:05
An: MapGuide Users Mail List
Betreff: Re: [mapguide-users] Loading dwf without Mapguide Studio
Not that I know of.
There are no FDO providers capable of displaying DWF files:
http://fdo.osgeo.org/OSProviderOverviews.html
I belive Studio extracts the data from the DWF, and inserts it as SDF data in the server (but I have not tried it).
There exists a DWF toolkit, so you may do this manually:
http://usa.autodesk.com/adsk/servlet/index?id=823771&siteID=123112
I'm guessing it will take some time to get it all to work.
If you can live with Studio only being avalible on the windows platform, it is
possible to call Studio via. .Net and perform the loads without manual intervention.
Regards, Kenneth Skovhede, GEOGRAF A/S
Stephan HOLLAUS skrev:
Hi
Is there a way to load dwf Files without Mapguide Studio?
thx
mfg Stephan Hollaus
Brandströmgasse 10
3100 St. Pölten
V55BCPWP
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080521/f3f128eb/attachment.html
