[mapguide-users] .NET Objects for working with Mapguide Resources
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Sat May 24 17:22:54 EDT 2008
Yes. I have moved the entire site over on the MapGuide wiki.
Documentation can now be found here:
http://trac.osgeo.org/mapguide/wiki/maestro
And for the API:
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI
Too bad about the LinQ dependancy, it would be a lot cleaner to do it
that way.
I have not exposed functionality in the way you ask, but it is there.
You can do it with code like this:
Stream s = ... stream with Xml data ...
LayerDefinition layer =
(LayerDefinition)con.DeserializeObject(typeof(LayerDefinition), s);
layer.BackgroundColor = Color.White;
s = con.SerializeObject(s);
The methods could actually be static, but they are not because they use
the server version to restrict/convert the version's of the documents.
It is possible to serialize/deserialise the objects manually, using the
XmlSerializer from .Net:
XmlSerializer ser = new XmlSerializer(typeof(LayerDefinition));
layer = (LayerDefinition)con.Deserialize(s);
layer.BackgroundColor = Color.Green;
ser.Serialize(s, layer);
There is a function in the Utility class that strips the UTF-8 BOM:
s = Utility.RemoveUTF8BOM(s);
Regards, Kenneth Skovhede, GEOGRAF A/S
Darrin Maidlow skrev:
> Hi Kenneth,
> Thanks for the feedback. You are very right in that dual development
> streams would be a bad thing and a waste of a lot of time. What I
> was hoping to accomplish with that XSD codegen was to create a set of
> relatively light weight objects to roundtrip the xml. Eliminate the
> use of XML tools for working with the mapguide entities, then return
> the entities back to XML for use with the Mapguide API. I was not
> planning a full API project. Again, you are right in that there is
> still some messing around needed to be done with the linq code -- I
> had problems with nulls just as you mentioned =)
> To answer your question, as far as I can see, the linq dll is required
> for the generated code to function. A lot of the generated
> functionality requires methods that exist within the linq to XSD dll file.
> I spent some time trying to find more info on the MeastroAPI today,
> but was not able to find much. Likely because of the move over to
> osgeo. I have not had a chance to actually work with the API again
> yet, but perhaps you could answer a couple questions for me.
> Does Meastro API come with the abovementioned objects I was looking
> for? Can I shove some XML from the repository into a new object, do
> some work, and then spit the new XML back out? If so, I'm assuming
> that I could continue to work with the web tier API from Mapguide?
> thx
> darrin
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* Thursday, May 22, 2008 12:04 PM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] .NET Objects for working with Mapguide
> Resources
> That is a smart way to convert Xsd to classes. Is it possible to
> extract the generated code and use it without LinQ for .Net 2.0?
> I'm not sure what you mean by "wanted to stay closer to the core API".
> Your generated classes expose the MapGuide Xml as .Net classes.
> You can then use .Net objects "directly" instead of handling Xml. That
> is exactly what the MaestroAPI does.
> I have implemented a connection interface that enables you to
> communicate with MapGuide either via the MapGuide API, or through Http.
> If you use the LocalNativeConnection exclusively, MaestroAPI is doing
> the exact same thing your code does.
> If you (or someone else) has questions about MaestroAPI usage, please
> ask away.
> If you (or someone else) find missing functionality, or has
> improvements for MaestroAPI, let me know.
> I have a short introduction to MaestroAPI usage here:
> http://code.google.com/p/mapstudioos/wiki/HowToUseMapGuideAPI
> (The site is being migrated to here:
> http://trac.osgeo.org/mapguide/wiki/maestro)
> I like your code, and if you are up for it, I think we both could
> benefit from one great API extension, rather than two good ones.
> I have learned that after you have the serialization in place there
> are many places where you must handle trivial stuff like
> converting null string to empty string, empty collections to null
> collections, etc. MaestroAPI handles much of this already,
> and I would be sad to see you spend your time implementing that for
> another project.
> Hi Maksim,
> I looked at early on in my learnage, but wanted to stay closer to the
> core API provided by Mapguide Project / Autodesk. ADN support could
> offer some help with the built in API, and if needed escalate off to
> the devs. I did also have some problems getting the Maestro API
> running -- but that was right around the transition between 1.1 and
> 2.0 -- and working all night with too much redbull probably didn't
> help either =)
> darrin
> <mailto:mapguide-users-bounces at lists.osgeo.org>
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Maksim
> Sestic
> *Sent:* Thursday, May 22, 2008 7:40 AM
> *To:* 'MapGuide Users Mail List'
> *Subject:* RE: [mapguide-users] .NET Objects for working with Mapguide
> Resources
> Hi Darrin,
> Thanks for the tip. Please take a look at Kenneth's Meastro API:
> http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/MaestroAPI
> It relies on .NET 2.0 for MG types (de)serialization.
> Regards,
> Maksim Sestic
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Darrin
> Maidlow
> *Sent:* Thursday, May 22, 2008 15:28
> *To:* mapguide-users at lists.osgeo.org
> <mailto:mapguide-users at lists.osgeo.org>
> *Subject:* [mapguide-users] .NET Objects for working with Mapguide
> Resources
> Hi List,
> I've written two posts I thought I would share with you on the topic
> of .NET based MG dev. The first describes a method I've worked out to
> create relatively robust .NET based objects based on the Xml Schema
> Definitions provided with the server. Please note, I currently am
> only working with MGE 2009. I have not tried this code on MGOS. If
> you do try them on MGOS, please let me know what results have.
> In a nutshell, one can get the resource XML from the resource service,
> load it into the object with the provided .parse method, manipulate
> the object (without having to use xml) e.g. add child objects, change
> properties etc, and finally spit it back out to XML for saving back to
> the repository. Yay no longer need to be jealous of the PHP guys and
> their object factories =D
> The second is a dynamic authoring example using these objects,
> manipulating the MapDefinition before the viewer has loaded it.
> Both come with full source code, and Visual Studio 2008 projects. I
> hope they are helpful to the other .NET devs out there.
> http://www.webrade.com/blogs/darrin/2008/05/16/CreatingNETObjectsForMapguideXMLSchemaDefinitionsXSDUsingLINQ.aspx
> http://www.webrade.com/blogs/darrin/2008/05/21/DynamicAuthoringInMapguideEnterpriseBeforeTheViewerHasLoaded.aspx
> Enjoy.
> darrin
> __________ NOD32 3118 (20080521) Information __________
> This message was checked by NOD32 antivirus system.
> http://www.eset.com
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080524/74388a55/attachment.html
