[mapguide-users] .NET Objects for working with Mapguide Resources
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sat May 24 18:13:26 EDT 2008
I'm not sure what you mean by "work with the web tier API".
There are two different API's that are refered to as Web tier, the
MapGuideDotNetApi.dll and the http interface.
Both of them are supported by MaestroAPI, using the LocalNativeConnetion
and HttpServerConnection.
You can set up a http connection like this:
ServerConnectionI connection = new HttpServerConnection(new
Uri("http://localhost/mapguide/mapagent/mapagent.fcgi"), "Anonymous", "");
And one using the local connection like this:
LocalNativeConnection("serverconfig.ini", "Anonymous", "");
The http connection is portable and does not require the mapguide dll's.
The native is a bit faster, because the http protocol and webserver
introduces overhead.
Once you have a connection, you can read an object from the repository,
using either interface, by issuing the following:
LayerDefinition layer =
connection.GetLayerDefinition("Library://layer.LayerDefinition");
And write it back like this:
connection.SaveResource(layer);
Or modify, and save under a new name:
layer.BackgroundColor = Color.Blue;
connection.SaveResource(layer, "Library://new layer.LayerDefinition");
There are also functions to generate the full paths, from name and type.
Regards, Kenneth Skovhede, GEOGRAF A/S
Kenneth Skovhede, GEOGRAF A/S skrev:
> Yes. I have moved the entire site over on the MapGuide wiki.
> Documentation can now be found here:
> http://trac.osgeo.org/mapguide/wiki/maestro
> And for the API:
> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI
> Too bad about the LinQ dependancy, it would be a lot cleaner to do it
> that way.
> I have not exposed functionality in the way you ask, but it is there.
> You can do it with code like this:
> Stream s = ... stream with Xml data ...
> (LayerDefinition)con.DeserializeObject(typeof(LayerDefinition), s);
> layer.BackgroundColor = Color.White;
> s = con.SerializeObject(s);
> The methods could actually be static, but they are not because they
> use the server version to restrict/convert the version's of the documents.
> It is possible to serialize/deserialise the objects manually, using
> the XmlSerializer from .Net:
> XmlSerializer ser = new XmlSerializer(typeof(LayerDefinition));
> layer = (LayerDefinition)con.Deserialize(s);
> layer.BackgroundColor = Color.Green;
> ser.Serialize(s, layer);
> There is a function in the Utility class that strips the UTF-8 BOM:
> s = Utility.RemoveUTF8BOM(s);
> Darrin Maidlow skrev:
>> Hi Kenneth,
>> Thanks for the feedback.  You are very right in that dual development
>> streams would be a bad thing and a waste of a lot of time.   What I
>> was hoping to accomplish with that XSD codegen was to create a set of
>> relatively light weight objects to roundtrip the xml.  Eliminate the
>> use of XML tools for working with the mapguide entities, then return
>> the entities back to XML for use with the Mapguide API.    I was not
>> planning a full API project.  Again, you are right in that there is
>> still some messing around needed to be done with the linq code -- I
>> had problems with nulls just as you mentioned =)
>> To answer your question, as far as I can see, the linq dll is
>> required for the generated code to function.  A lot of the generated
>> functionality requires methods that exist within the linq to XSD dll
>> file.
>> I spent some time trying to find more info on the MeastroAPI today,
>> but was not able to find much.  Likely because of the move over to
>> osgeo.  I have not had a chance to actually work with the API again
>> yet, but perhaps you could answer a couple questions for me.
>> Does Meastro API come with the abovementioned objects I was looking
>> for?  Can I shove some XML from the repository into a new object, do
>> some work, and then spit the new XML back out?  If so, I'm assuming
>> that I could continue to work with the web tier API from Mapguide?
>> thx
>> darrin
>> *From:* mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
>> *Kenneth Skovhede, GEOGRAF A/S
>> *Sent:* Thursday, May 22, 2008 12:04 PM
>> *To:* MapGuide Users Mail List
>> *Subject:* Re: [mapguide-users] .NET Objects for working with
>> Mapguide Resources
>> That is a smart way to convert Xsd to classes. Is it possible to
>> extract the generated code and use it without LinQ for .Net 2.0?
>> I'm not sure what you mean by "wanted to stay closer to the core
>> API". Your generated classes expose the MapGuide Xml as .Net classes.
>> You can then use .Net objects "directly" instead of handling Xml.
>> That is exactly what the MaestroAPI does.
>> I have implemented a connection interface that enables you to
>> communicate with MapGuide either via the MapGuide API, or through Http.
>> If you use the LocalNativeConnection exclusively, MaestroAPI is doing
>> the exact same thing your code does.
>> If you (or someone else) has questions about MaestroAPI usage, please
>> ask away.
>> If you (or someone else) find missing functionality, or has
>> improvements for MaestroAPI, let me know.
>> I have a short introduction to MaestroAPI usage here:
>> http://code.google.com/p/mapstudioos/wiki/HowToUseMapGuideAPI
>> (The site is being migrated to here:
>> http://trac.osgeo.org/mapguide/wiki/maestro)
>> I like your code, and if you are up for it, I think we both could
>> benefit from one great API extension, rather than two good ones.
>> I have learned that after you have the serialization in place there
>> are many places where you must handle trivial stuff like
>> converting null string to empty string, empty collections to null
>> collections, etc. MaestroAPI handles much of this already,
>> and I would be sad to see you spend your time implementing that for
>> another project.
>> Hi Maksim,
>> I looked at early on in my learnage, but wanted to stay closer to the
>> core API provided by Mapguide Project / Autodesk.   ADN support could
>> offer some help with the built in API, and if needed escalate off to
>> the devs.  I did also have some problems getting the Maestro API
>> running -- but that was right around the transition between 1.1 and
>> 2.0 -- and working all night with too much redbull probably didn't
>> help either =)
>> darrin
>> <mailto:mapguide-users-bounces at lists.osgeo.org>
>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Maksim
>> Sestic
>> *Sent:* Thursday, May 22, 2008 7:40 AM
>> *To:* 'MapGuide Users Mail List'
>> *Subject:* RE: [mapguide-users] .NET Objects for working with
>> Mapguide Resources
>> Hi Darrin,
>> Thanks for the tip. Please take a look at Kenneth's Meastro API:
>> http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/MaestroAPI
>> It relies on .NET 2.0 for MG types (de)serialization.
>> Regards,
>> Maksim Sestic
>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Darrin
>> Maidlow
>> *Sent:* Thursday, May 22, 2008 15:28
>> *To:* mapguide-users at lists.osgeo.org
>> <mailto:mapguide-users at lists.osgeo.org>
>> *Subject:* [mapguide-users] .NET Objects for working with Mapguide
>> Resources
>> Hi List,
>> I've written two posts I thought I would share with you on the topic
>> of .NET based MG dev.  The first describes a method I've worked out
>> to create relatively robust .NET based objects based on the Xml
>> Schema Definitions provided with the server.    Please note, I
>> currently am only working with MGE 2009.  I have not tried this code
>> on MGOS.  If you do try them on MGOS, please let me know what results
>> have.
>> In a nutshell, one can get the resource XML from the resource
>> service, load it into the object with the provided .parse method,
>> manipulate the object (without having to use xml) e.g. add child
>> objects, change properties etc, and finally spit it back out to XML
>> for saving back to the repository.  Yay no longer need to be jealous
>> of the PHP guys and their object factories =D
>> The second is a dynamic authoring example using these objects,
>> manipulating the MapDefinition before the viewer has loaded it.
>> Both come with full source code, and Visual Studio 2008 projects.   I
>> hope they are helpful to the other .NET devs out there.
>> http://www.webrade.com/blogs/darrin/2008/05/16/CreatingNETObjectsForMapguideXMLSchemaDefinitionsXSDUsingLINQ.aspx
>> http://www.webrade.com/blogs/darrin/2008/05/21/DynamicAuthoringInMapguideEnterpriseBeforeTheViewerHasLoaded.aspx
>> Enjoy.
>> darrin
>> __________ NOD32 3118 (20080521) Information __________
>> This message was checked by NOD32 antivirus system.
>> http://www.eset.com
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080525/8db1e8ad/attachment.html
