[mapguide-users] MapStudio Open Source - MgDbXmlException
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue May 27 04:10:15 EDT 2008
Yes, Zac is right, it is a drive on the build machine.
I think I recall there was a problem with the map editor.
You have to type something in the "Legend label" field.
You can erase it afterwards, and you should be fine.
If that solves the problem, it has been fixed in the development, and
will be part of the next release.
Regards, Kenneth Skovhede, GEOGRAF A/S
Zac Spitzer skrev:
> the "d:\buildforgeprojects\mapguide_open_source_v2.0" is just a
> reference to where mapguide
> was compiled from
> On Tue, May 27, 2008 at 3:16 AM, geofleming <krabjohn at flemingc.on.ca> wrote:
>> HI Thanks foer the reply.
>> I looked in the log and I noticed a few things like it is referencing a
>> d:\buildforgeprojects\mapguide_open_source_v2.0 I don't even have a d drive.
>> Here is what the error log says. When I try to save a .map
>> I made a connection, saved a layer with one shp file, (should I be adding
>> all parts of the shapfile or is .shp the only one you need?)
>> Then I add this layer into the map and try to save it, that's when I get
>> this error.
>> Error: An exception occurred in DB XML component.
>> Error: XML Indexer: Parse error in document at line, 21, char 14.
>> Parser message: Element 'ExpandInLegend' is not valid for content model:
>> '((Name,ResourceId,Selectable,ShowInLegend,LegendLabel),ExpandInLegend,Visible,Group)'
>> StackTrace:
>> - MgResourceServiceHandler.ProcessOperation line 80 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
>> - MgOpSetResource.Execute line 103 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\resource\OpSetResource.cpp
>> - MgServerResourceService.SetResource line 713 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\resource\ServerResourceService.cpp
>> - MgRepositoryManager.SetResource line 867 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\resource\RepositoryManager.cpp
>> - MgRepositoryManager.AddResource line 840 file
>> - MgResourceContentManager.AddResource line 183 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\resource\ResourceContentManager.cpp
>> - MgResourceContentManager.PutDocument line 624 file
>> - MgResourceDefinitionManager.PutDocument line 554 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
>> Error: XML Indexer: Parse error in document at line, 21, char 14. Parser
>> As you can probly tell I am a newbie with mapguide OS, but I have used many
>> other Web GIS sytems including Mapguide 6.3.
>> Thanks, Kevin
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>> When that happens, it is because the Xml is not valid.
>>> In the server log, there is a more detailed description of the error:
>>> C:\program files\MapGuideOpenSource2.0\server\logs\error.log
>>> Using that information, you may be able to guess what the problem is.
>>> If you figure it out, please let me know
>>> If not, can you explain, step by step, what you did to produce this error?
>>> I would appreciate it if you created a ticket for this problem:
>>> http://trac.osgeo.org/mapguide/newticket
>>> In the component field, make sure you select "Maestro" (that is the new
>>> name for MapStudio OS).
>>> geofleming skrev:
>>>> I am also getting this error when trying to make a map.
>>>> I have tried different data, even tried the sheboygan sdf files but still
>>>> nothing. Is it a rights issue on the server? Something not registered? I
>>>> have installed mapguide os on both a win 2003 server and Xp pro using the
>>>> bundles software and the demo data works great but thats all that works.
>>>> Thanks for any help.
>>>> Kevin
>>>> Viva_Rose wrote:
>>>>> i having this error when i try to save the xxxx.map
>>>>> Wat should i do to prevent this error....
>>>>> http://www.nabble.com/file/p17097041/Error.bmp
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context: http://www.nabble.com/MapStudio-Open-Source---MgDbXmlException-tp17097041p17475725.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080527/2dada19a/attachment.html
