[mapguide-users] MapStudio Open Source - MgDbXmlException
Zac Spitzer
zac.spitzer at gmail.com
Mon May 26 21:58:09 EDT 2008
the "d:\buildforgeprojects\mapguide_open_source_v2.0" is just a
reference to where mapguide
was compiled from
On Tue, May 27, 2008 at 3:16 AM, geofleming <krabjohn at flemingc.on.ca> wrote:
> HI Thanks foer the reply.
> I looked in the log and I noticed a few things like it is referencing a
> d:\buildforgeprojects\mapguide_open_source_v2.0 I don't even have a d drive.
> Here is what the error log says. When I try to save a .map
> I made a connection, saved a layer with one shp file, (should I be adding
> all parts of the shapfile or is .shp the only one you need?)
> Then I add this layer into the map and try to save it, that's when I get
> this error.
> Error: An exception occurred in DB XML component.
> Error: XML Indexer: Parse error in document at line, 21, char 14.
> Parser message: Element 'ExpandInLegend' is not valid for content model:
> '((Name,ResourceId,Selectable,ShowInLegend,LegendLabel),ExpandInLegend,Visible,Group)'
> StackTrace:
> - MgResourceServiceHandler.ProcessOperation line 80 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
> - MgOpSetResource.Execute line 103 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\resource\OpSetResource.cpp
> - MgServerResourceService.SetResource line 713 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\resource\ServerResourceService.cpp
> - MgRepositoryManager.SetResource line 867 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\resource\RepositoryManager.cpp
> - MgRepositoryManager.AddResource line 840 file
> - MgResourceContentManager.AddResource line 183 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\resource\ResourceContentManager.cpp
> - MgResourceContentManager.PutDocument line 624 file
> - MgResourceDefinitionManager.PutDocument line 554 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
> Error: XML Indexer: Parse error in document at line, 21, char 14. Parser
> As you can probly tell I am a newbie with mapguide OS, but I have used many
> other Web GIS sytems including Mapguide 6.3.
> Thanks, Kevin
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> When that happens, it is because the Xml is not valid.
>> In the server log, there is a more detailed description of the error:
>> C:\program files\MapGuideOpenSource2.0\server\logs\error.log
>> Using that information, you may be able to guess what the problem is.
>> If you figure it out, please let me know
>> If not, can you explain, step by step, what you did to produce this error?
>> I would appreciate it if you created a ticket for this problem:
>> http://trac.osgeo.org/mapguide/newticket
>> In the component field, make sure you select "Maestro" (that is the new
>> name for MapStudio OS).
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> geofleming skrev:
>>> I am also getting this error when trying to make a map.
>>> I have tried different data, even tried the sheboygan sdf files but still
>>> nothing. Is it a rights issue on the server? Something not registered? I
>>> have installed mapguide os on both a win 2003 server and Xp pro using the
>>> bundles software and the demo data works great but thats all that works.
>>> Thanks for any help.
>>> Kevin
>>> Viva_Rose wrote:
>>>> i having this error when i try to save the xxxx.map
>>>> Wat should i do to prevent this error....
>>>> http://www.nabble.com/file/p17097041/Error.bmp
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://www.nabble.com/MapStudio-Open-Source---MgDbXmlException-tp17097041p17475725.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
