[ZS1] Re: [mapguide-users] raster help - seriously....
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Tue May 27 13:51:41 EDT 2008
I'm just super happy to finally have gotten it working.....I figured it
had to be a simple mistake I'd made.
Kenneth Skovhede, GEOGRAF A/S wrote:
> Very strange about the libpq. It is a PostGIS dll and should not be
> activated unless you use the PostGIS provider.
> I have done the exact procedure a number of times on various machines,
> without problems.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Andrew DeMerchant skrev:
>> Your step #4 and 5 aren't on the wiki at all
>> (http://trac.osgeo.org/fdo/wiki/FdoGdalNotes). Actually, I tried that
>> based on your email, and it broke MSOS (now named Maestro, I guess).
>> I could no longer make any new data connections - kept getting a
>> message on the server that I was missing libpq.dll - which doesn't
>> exist anywhere....What I ended up doing was reverting to my original
>> FDO folder (that came with MGOS 2.0)....I noticed your step #10 - and
>> it does say that on the wiki, but I totally missed it. I'd copied the
>> "gdalplugins" folder to "Server/Bin/Fdo/", rather than "server/bin"!
>> Anyway, that was my problem....I'd tried everything. Thanks so much!!
>> Andrew
>>> I have rasters (GDAL/ECW) working in 2.0.
>>> The procedure I took was this:
>>> 1. Install MgServer
>>> 2. Install MgWebExt
>>> 3. Stop MapGuide service
>>> 4. Remove FDO folder (C:\Program
>>> files\MapGuideOpenSource\Server\Bin\FDO)
>>> 5. Download win32 FDO SDK here:
>>> http://fdo.osgeo.org/content/fdo-331-downloads#3.3.1_win_binaries
>>> 6. Untar (that is extract) the files.
>>> 7. Rename folder "bin" to FDO
>>> 8. Place the FDO folder instead of the one deleted in step 4
>>> 9. Download ECW plugin from here:
>>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#MrSIDandECWPluginSupportWindows
>>> Well actually, select "ecw" here http://home.gdal.org/dl/gdal14_vc8/
>>> 10. Place the "gdalplugins" folder in C:\Program
>>> files\MapGuideOpenSource\Server\Bin, this gives a final path like this:
>>> C:\Programmer\MapGuideOpenSource2.0\Server\Bin\gdalplugins\gdal_ECW.dll
>>> 11. Restart the MapGuide service.
>>> I assume the same holds for mrsid.
>>> mrsyer skrev:
>>>> Hey Andrew, I've suffered the same problem on 2.0. I didn't migrate
>>>> this was
>>>> my first use of open source. See my problem under the thread
>>>> 'repairing open
>>>> source'. Anyways I tried using this solution from the rasters.zip
>>>> folder,
>>>> but then I couldn't read any of my data, now I can't log into my
>>>> site or
>>>> uninstall the program so beware if you do use the rasters.zip.
>>>> Anyways good
>>>> luck.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> *Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
