[ZS1] Re: [mapguide-users] raster help - seriously....
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue May 27 13:49:33 EDT 2008
Very strange about the libpq. It is a PostGIS dll and should not be
activated unless you use the PostGIS provider.
I have done the exact procedure a number of times on various machines,
without problems.
Regards, Kenneth Skovhede, GEOGRAF A/S
Andrew DeMerchant skrev:
> Your step #4 and 5 aren't on the wiki at all
> (http://trac.osgeo.org/fdo/wiki/FdoGdalNotes). Actually, I tried that
> based on your email, and it broke MSOS (now named Maestro, I guess). I
> could no longer make any new data connections - kept getting a message
> on the server that I was missing libpq.dll - which doesn't exist
> anywhere....What I ended up doing was reverting to my original FDO
> folder (that came with MGOS 2.0)....I noticed your step #10 - and it
> does say that on the wiki, but I totally missed it. I'd copied the
> "gdalplugins" folder to "Server/Bin/Fdo/", rather than "server/bin"!
> Anyway, that was my problem....I'd tried everything. Thanks so much!!
> Andrew
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> I have rasters (GDAL/ECW) working in 2.0.
>> The procedure I took was this:
>> 1. Install MgServer
>> 2. Install MgWebExt
>> 3. Stop MapGuide service
>> 4. Remove FDO folder (C:\Program
>> files\MapGuideOpenSource\Server\Bin\FDO)
>> 5. Download win32 FDO SDK here:
>> http://fdo.osgeo.org/content/fdo-331-downloads#3.3.1_win_binaries
>> 6. Untar (that is extract) the files.
>> 7. Rename folder "bin" to FDO
>> 8. Place the FDO folder instead of the one deleted in step 4
>> 9. Download ECW plugin from here:
>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#MrSIDandECWPluginSupportWindows
>> Well actually, select "ecw" here http://home.gdal.org/dl/gdal14_vc8/
>> 10. Place the "gdalplugins" folder in C:\Program
>> files\MapGuideOpenSource\Server\Bin, this gives a final path like this:
>> C:\Programmer\MapGuideOpenSource2.0\Server\Bin\gdalplugins\gdal_ECW.dll
>> 11. Restart the MapGuide service.
>> I assume the same holds for mrsid.
>> mrsyer skrev:
>>> Hey Andrew, I've suffered the same problem on 2.0. I didn't migrate
>>> this was
>>> my first use of open source. See my problem under the thread
>>> 'repairing open
>>> source'. Anyways I tried using this solution from the rasters.zip
>>> folder,
>>> but then I couldn't read any of my data, now I can't log into my
>>> site or
>>> uninstall the program so beware if you do use the rasters.zip.
>>> Anyways good
>>> luck.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> 	*Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
Skipped content of type multipart/related
