[ZS1] Re: [mapguide-users] raster help - seriously....
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Tue May 27 13:04:04 EDT 2008
Your step #4 and 5 aren't on the wiki at all
(http://trac.osgeo.org/fdo/wiki/FdoGdalNotes). Actually, I tried that
based on your email, and it broke MSOS (now named Maestro, I guess). I
could no longer make any new data connections - kept getting a message
on the server that I was missing libpq.dll - which doesn't exist
anywhere....What I ended up doing was reverting to my original FDO
folder (that came with MGOS 2.0)....I noticed your step #10 - and it
does say that on the wiki, but I totally missed it. I'd copied the
"gdalplugins" folder to "Server/Bin/Fdo/", rather than "server/bin"!
Anyway, that was my problem....I'd tried everything. Thanks so much!!
Andrew
Kenneth Skovhede, GEOGRAF A/S wrote:
> I have rasters (GDAL/ECW) working in 2.0.
> The procedure I took was this:
> 1. Install MgServer
> 2. Install MgWebExt
> 3. Stop MapGuide service
> 4. Remove FDO folder (C:\Program files\MapGuideOpenSource\Server\Bin\FDO)
> 5. Download win32 FDO SDK here:
> http://fdo.osgeo.org/content/fdo-331-downloads#3.3.1_win_binaries
> 6. Untar (that is extract) the files.
> 7. Rename folder "bin" to FDO
> 8. Place the FDO folder instead of the one deleted in step 4
> 9. Download ECW plugin from here:
> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#MrSIDandECWPluginSupportWindows
> Well actually, select "ecw" here http://home.gdal.org/dl/gdal14_vc8/
> 10. Place the "gdalplugins" folder in C:\Program
> files\MapGuideOpenSource\Server\Bin, this gives a final path like this:
> C:\Programmer\MapGuideOpenSource2.0\Server\Bin\gdalplugins\gdal_ECW.dll
> 11. Restart the MapGuide service.
> I assume the same holds for mrsid.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> mrsyer skrev:
>> Hey Andrew, I've suffered the same problem on 2.0. I didn't migrate
>> this was
>> my first use of open source. See my problem under the thread
>> 'repairing open
>> source'. Anyways I tried using this solution from the rasters.zip
>> folder,
>> but then I couldn't read any of my data, now I can't log into my site or
>> uninstall the program so beware if you do use the rasters.zip.
>> Anyways good
>> luck.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
