[mapguide-users] Newbie needs help with project to query web layouts
sweet_reshma 7486ster at gmail.com
Wed May 28 03:36:55 EDT 2008
Sir,Actually this is not as reply to your query but this is a request for
help . I am totally new to mapguide open source. I used rhel4 Linux os.I
want to install mapguide server (open source). I tried for that 4-5 times
but i failed everytime.Please help me for step-by-step process of
installation.i faced problem like php failed.... most errors like.. path
problem ,fdo thirdparty.......custom path not found....invalid path..
i am totally confused how to set path, exactly where should i extract
perticular folder of fdo like?..
Also tell me...is there any more softwares required for building and
configuration for eg...software for Arcsde,mysql.Please send me reply.
Nick Aizen wrote:
> Can anyone help me with this process, I'm new to both web development and
> MapGuide API development, so please excuse me if I don't ask my question
> the correct way but basically....
> I want to be able to load a weblayout (created in MG Studio),  when my
> asp.net page loads and query and zoom on the map in the weblayout before
> the page is fully displayed. Basically I will be calling the asp.net page
> from an application passing it parameters for the query functionality.
>  I would appreciate it if someone can provide a code snippet. I'm using as
> my base, one of the examples provided on the Autodesk web site. I can
> provide any information regarding the project being used if that will
> help. Also, other than the PDF's provided my Autodesk are there any
> helpful resources for developers?
> Here's the code when the page loads that loads a weblayout:
>   MgUserInformation userInfo = new MgUserInformation("Administrator",
> "admin");
>     MgSite site = new MgSite();
>     site.Open(userInfo);
>     String sessionId = site.CreateSession();
>     String webLayout = "Library://DevTV/HelloWorld.WebLayout";
> 'Need help with API to query and zoom'
> Then the layout is passed to the viewer.
> <frameset rows="0,*" border="0" framespacing="0">
>   <frame />
>   <frame src="/mapguide2008/mapviewernet/ajaxviewer.aspx?SESSION=<%=
> sessionId %>&WEBLAYOUT=<%= webLayout %>" name="ViewerFrame" />
> </frameset>
> Many Thanks,
> Nick Aizen
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Newbie-needs-help-with-project-to-query-web-layouts-tp17005960p17359145.html
