[ZS2] [mapguide-users] What happens if the BBOX does not exist?
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed May 28 03:56:44 EDT 2008
You should provide more surrounding code, or say where the code is from.
In the code below, the envelope is never used, so it doesn't matter if
it is there.
I assume it was supposed to be combined with the attribute filter like this:
if ($queryEnvelope != null)
$queryOptions->SetSpatialFilter($queryEnvelope)
Regards, Kenneth Skovhede, GEOGRAF A/S
¾Ï±ó skrev:
> Why the 'BBOX' does not exist?If this happens,can I get the 'geometry'?
> the codes is as following:
> if (array_key_exists('BBOX', $_GET))
> // split the client's BBOX return by commas and spaces to obtain an
> array of coordinates
> $coords = preg_split('/,|\s/', $_GET['BBOX']);
> $lowerLeft = $geometryFactory->CreateCoordinateXY($coords[0], $coords[1]);
> $upperRight = $geometryFactory->CreateCoordinateXY($coords[2],
> $coords[3]);
> $queryEnvelope = new MgEnvelope($lowerLeft, $upperRight);
> $featureService =
> $siteConnection->CreateService(MgServiceType::FeatureService);
> $queryOptions = new MgFeatureQueryOptions();
> $filter = urldecode($_GET["FILTER"]) ;
> //echo "<p>$filter</p>";
> echo '<Folder>';
> echo '<description>MapGuide - Wheaton Parcels Filtered ['.$filter.']
> </description>';
> echo '<name>Wheaton Parcels</name>';
> echo '<visibility>0</visibility>';
> echo '<open>1</open>';
> $queryOptions->SetFilter($filter);
> //Feature Source being used in the application
> $featureReader = $featureService->SelectFeatures(new
> MgResourceIdentifier("Library://test/Data/province.FeatureSource"),
> "province", $queryOptions);
> //if($featureReader!=null) echo "<p>feature success!</p>";
> $geometryReaderWriter = new MgAgfReaderWriter();
> echo '<p>test1</p>';
> //Read Feature Source Attributes for populating Tooltip on Google Earth
> //Change this if using a different Feature Source
> $byteReader = $featureReader->GetGeometry('Geometry');
> //if($byteReader) echo '<p>feature success!</p>';
> $geometry = $geometryReaderWriter->Read($byteReader);
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080528/7e2cd9ab/attachment.html
