[ZS2] =?x-gbk?Q?=BB=D8=B8=B4=3A_=5BZS2=5D_=5Bmapguide-us?=
=?x-gbk?Q?ers=5D_What_happens_if_the_BBOX_does_not_exist?=
=?x-gbk?Q?=3F?=
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed May 28 04:43:53 EDT 2008
I see no problem with it.
The filter is bascially an SQL statement, so you can try changing the
URL to:
http://localhost:8008/mapguide/test/KMLContentFactory.php?FILTER=FID>0
<http://localhost:8008/mapguide/test/KMLContentFactory.php?FILTER=%22.urlencode%28$_GET%5B%22PropertyName>
Where FID is an existing numeric column.
Regards, Kenneth Skovhede, GEOGRAF A/S
¾Ï±ó skrev:
> my codes is from the http://mapguide.osgeo.org/livegallery.htmland I
> want to do the same thing as
> http://data.mapguide.com/mapguide/DynamicKml/GoogleEarth.php¡¡£Éjust
> used their codes and use my data instead,but I can't get the right result.
> If there is no BBOX,can I get the Geometry?
> the file which invoke that function is just as follows.
> --¾Ï±ó
> <?php
> //This file delivers KML network link content directly
> //to Google Earth.
> include 'UtilityFunctions.php';
> //uses the Wrapper.kml file for KML Network Link Skeleton
> $doc = DOMDocument::load('Wrapper.kml');
> $networkLinkNode = $doc->getElementsByTagName('href')->item(0);
> $networkLinkNode->nodeValue =
> "http://localhost:8008/mapguide/test/KMLContentFactory.php?FILTER=".urlencode($_GET["PropertyName
> <http://localhost:8008/mapguide/test/KMLContentFactory.php?FILTER=%22.urlencode%28$_GET%5B%22PropertyName>"]."
> ".$_GET["Operator"]." ".$_GET["VAL"]);
> $layerDefinition = $doc->saveXML();
> header('Content-Type: application/keyhole');
> header('Content-Length: ' . strlen($layerDefinition));
> echo $layerDefinition;
> -- ----------------ÔʼÓʼþ------------------
> *·¢¼þÈË:*"Kenneth Skovhede, GEOGRAF A/S"<ks at geograf.dk>;
> *·¢ËÍʱ¼ä:*2008Äê5ÔÂ28ÈÕ(ÐÇÆÚÈý) ÏÂÎç03:56
> *ÊÕ¼þÈË:*"MapGuide Users Mail List"<mapguide-users at lists.osgeo.org>;
> *Ö÷Ìâ:*Re: [ZS2] [mapguide-users] What happens if the BBOX does not exist?
> You should provide more surrounding code, or say where the code is from.
> In the code below, the envelope is never used, so it doesn't matter if
> it is there.
> I assume it was supposed to be combined with the attribute filter like
> this:
> if ($queryEnvelope != null)
> $queryOptions->SetSpatialFilter($queryEnvelope)
> ¾Ï±ó skrev:
>> Why the 'BBOX' does not exist?If this happens,can I get the 'geometry'?
>> the codes is as following:
>> if (array_key_exists('BBOX', $_GET))
>> // split the client's BBOX return by commas and spaces to obtain an
>> array of coordinates
>> $coords = preg_split('/,|\s/', $_GET['BBOX']);
>> $lowerLeft = $geometryFactory->CreateCoordinateXY($coords[0],
>> $coords[1]);
>> $upperRight = $geometryFactory->CreateCoordinateXY($coords[2],
>> $coords[3]);
>> $queryEnvelope = new MgEnvelope($lowerLeft, $upperRight);
>> $featureService =
>> $siteConnection->CreateService(MgServiceType::FeatureService);
>> $queryOptions = new MgFeatureQueryOptions();
>> $filter = urldecode($_GET["FILTER"]) ;
>> //echo "<p>$filter</p>";
>> echo '<Folder>';
>> echo '<description>MapGuide - Wheaton Parcels Filtered ['.$filter.']
>> </description>';
>> echo '<name>Wheaton Parcels</name>';
>> echo '<visibility>0</visibility>';
>> echo '<open>1</open>';
>> $queryOptions->SetFilter($filter);
>> //Feature Source being used in the application
>> $featureReader = $featureService->SelectFeatures(new
>> MgResourceIdentifier("Library://test/Data/province.FeatureSource"),
>> "province", $queryOptions);
>> //if($featureReader!=null) echo "<p>feature success!</p>";
>> $geometryReaderWriter = new MgAgfReaderWriter();
>> echo '<p>test1</p>';
>> //Read Feature Source Attributes for populating Tooltip on Google Earth
>> //Change this if using a different Feature Source
>> $byteReader = $featureReader->GetGeometry('Geometry');
>> //if($byteReader) echo '<p>feature success!</p>';
>> $geometry = $geometryReaderWriter->Read($byteReader);
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080528/a77187c4/attachment.html
