RE: SPAM-LOW: »Ø¸´: [ZS2] [mapguide-users] What happens if the BBOX does not exist?
Andy Morsell amorsell at spatialgis.com
Wed May 28 12:09:14 EDT 2008
If you are adding your PHP as a network link layer in Google Earth, Google Earth will issue a request to that page on any pan or zoom.  Part of that is the automatic passing of the Google Earth BBOX parameter.  Are you doing this from Google Earth?  No, the application will not work without BBOX.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of ??
Sent: Wednesday, May 28, 2008 1:00 AM
To: mapguide users mail list
Subject: SPAM-LOW: 回复: [ZS2] [mapguide-users] What happens if the BBOX does not exist?
my codes is from  the http://mapguide.osgeo.org/livegallery.html and I want to do the same thing as http://data.mapguide.com/mapguide/DynamicKml/GoogleEarth.php Ijust used their codes and use my data instead,but I can't get the right result.
If there is no BBOX,can I get the Geometry?
the file which invoke that function is just as follows.
                                                         --鞠斌
<?php
 //This file delivers KML network link content directly
 //to Google Earth.
 include 'UtilityFunctions.php';
 //uses the Wrapper.kml file for KML Network Link Skeleton
 $doc = DOMDocument::load('Wrapper.kml');
 $networkLinkNode = $doc->getElementsByTagName('href')->item(0);
 $networkLinkNode->nodeValue = "http://localhost:8008/mapguide/test/KMLContentFactory.php?FILTER=".urlencode($_GET["PropertyName <http://localhost:8008/mapguide/test/KMLContentFactory.php?FILTER=> "]." ".$_GET["Operator"]." ".$_GET["VAL"]);
 $layerDefinition = $doc->saveXML();
 header('Content-Type: application/keyhole');
 header('Content-Length: ' . strlen($layerDefinition));
 echo $layerDefinition;
------------------ 原始邮件 ------------------
发件人: "Kenneth Skovhede, GEOGRAF A/S"<ks at geograf.dk>;
发送时间: 2008年5月28日(星期三) 下午03:56
收件人: "MapGuide Users Mail List"<mapguide-users at lists.osgeo.org>;
主题: Re: [ZS2] [mapguide-users] What happens if the BBOX does not exist?
You should provide more surrounding code, or say where the code is from.
In the code below, the envelope is never used, so it doesn't matter if it is there.
I assume it was supposed to be combined with the attribute filter like this:
if ($queryEnvelope != null)
    $queryOptions->SetSpatialFilter($queryEnvelope)
Regards, Kenneth Skovhede, GEOGRAF A/S
鞠斌 skrev:
Why the 'BBOX' does not exist?If this happens,can I get the 'geometry'?
the codes is as following:
if (array_key_exists('BBOX', $_GET))
        // split the client's BBOX return by commas and spaces to obtain an array of coordinates
        $coords = preg_split('/,|\s/', $_GET['BBOX']);
        $lowerLeft = $geometryFactory->CreateCoordinateXY($coords[0], $coords[1]);
        $upperRight = $geometryFactory->CreateCoordinateXY($coords[2], $coords[3]);
        $queryEnvelope = new MgEnvelope($lowerLeft, $upperRight);
$featureService = $siteConnection->CreateService(MgServiceType::FeatureService);
    $queryOptions = new MgFeatureQueryOptions();
    $filter = urldecode($_GET["FILTER"]) ;
    //echo "<p>$filter</p>";
    echo '<Folder>';
    echo '<description>MapGuide - Wheaton Parcels Filtered ['.$filter.'] </description>';
    echo '<name>Wheaton Parcels</name>';
    echo '<visibility>0</visibility>';
    echo '<open>1</open>';
    $queryOptions->SetFilter($filter);
    //Feature Source being used in the application
    $featureReader = $featureService->SelectFeatures(new MgResourceIdentifier("Library://test/Data/province.FeatureSource"), "province", $queryOptions);
    //if($featureReader!=null) echo "<p>feature success!</p>";
    $geometryReaderWriter = new MgAgfReaderWriter();
    echo '<p>test1</p>';
    //Read Feature Source Attributes for populating Tooltip on Google Earth
    //Change this if using a different Feature Source
    $byteReader = $featureReader->GetGeometry('Geometry');
    //if($byteReader) echo '<p>feature success!</p>';
    $geometry = $geometryReaderWriter->Read($byteReader);
  _____
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080528/95d90388/attachment.html
