[ZS1] Re: [mapguide-users] raster help - seriously....
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed May 28 11:28:28 EDT 2008
If you get that message, your feature source is using the Autodesk
raster provider.
If you have MapGuide Enterprise 2009, you should re-install it.
If you upgrade FDO, be carefull not to overwrite the providers.xml file.
If you do not have MapGuide Enterprise 2009, but MapGuide Open Source 2.0.0,
you have to create the layer without load procedures. (I assume you are
using MapGuide Studio).
Select "New dataconnection" and select the GDAL provider.
In the dialog, enter the full path to the raster file/folder (try a
local path before a network path).
Regards, Kenneth Skovhede, GEOGRAF A/S
mrsyer skrev:
> hmmm, Ive tried all of these procedures and nothing seems to work. I still
> get a 'Server does not support file type: Autodesk.Raster' .... Any other
> solutions?
> Rock Beans wrote:
>> Did you try removing any ending slashes from your Raster Path feature
>> source? That fixed most of my issues.
>> Example:
>> C\Rasters\ <-- Broken in 2.0
>> C:\Rasters
>> The Rock
>> On Tue, May 27, 2008 at 9:59 AM, Andrew DeMerchant <
>> andrew.demerchant at gemtec.ca> wrote:
>>> Ok, I've asked before - but gotten either no response, or no working
>>> solution.....can someone please help get raster working for me? From what
>>> I
>>> hear, the GDAL works for some people in MGOS 2.0 - though it seems to be
>>> very few. PLEASE post a step by step guide as to how to get it up and
>>> running and how to make datasources and layers from it. Either it just
>>> plain
>>> doesn't work for me, or I'm doing something wrong repeatedly. I NEED to
>>> get
>>> rasters working again - which died after I "upgraded" to MGOS 2.0 from
>>> 1.0.2. Is there a way to make the old Autodesk raster provider work with
>>> 2.0? This really needs to get fixed....raster support is pretty critical.
>>> Andrew
>>> *Andrew DeMerchant*
>>> *Computer Technologist*
>>> ph.1-877-2GEMTEC x.163
>>> fax 506-453-9470
>>> *GEMTEC Limited <http://www.gemtec.ca>
>>> *191 Doak Road
>>> Fredericton, NB, Canada
>>> E3C 2E6
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080528/0be13c5c/attachment.html
