[mapguide-users] [ZS1] Re: raster help - seriously....
mrsyer
joey_syer at hotmail.com
Wed May 28 14:12:57 EDT 2008
The data connection works except when i preview my layer nothing is visible?
I originally installed 2.0.0, but then had some problems so i uninstalled
it. And by that time 2.0.1 was released so im running that. the plugins im
using are from the post in this thread, and they are for 2.0.0 could that be
an issue? thanks.
Kenneth Skovhede, GEOGRAF A/S wrote:
> If you get that message, your feature source is using the Autodesk
> raster provider.
> If you have MapGuide Enterprise 2009, you should re-install it.
> If you upgrade FDO, be carefull not to overwrite the providers.xml file.
> If you do not have MapGuide Enterprise 2009, but MapGuide Open Source
> 2.0.0,
> you have to create the layer without load procedures. (I assume you are
> using MapGuide Studio).
> Select "New dataconnection" and select the GDAL provider.
> In the dialog, enter the full path to the raster file/folder (try a
> local path before a network path).
> Regards, Kenneth Skovhede, GEOGRAF A/S
> mrsyer skrev:
>> hmmm, Ive tried all of these procedures and nothing seems to work. I
>> still
>> get a 'Server does not support file type: Autodesk.Raster' .... Any other
>> solutions?
>> Rock Beans wrote:
>>> Did you try removing any ending slashes from your Raster Path feature
>>> source? That fixed most of my issues.
>>> Example:
>>> C\Rasters\ <-- Broken in 2.0
>>> C:\Rasters
>>> The Rock
>>> On Tue, May 27, 2008 at 9:59 AM, Andrew DeMerchant <
>>> andrew.demerchant at gemtec.ca> wrote:
>>>> Ok, I've asked before - but gotten either no response, or no working
>>>> solution.....can someone please help get raster working for me? From
>>>> what
>>>> I
>>>> hear, the GDAL works for some people in MGOS 2.0 - though it seems to
>>>> be
>>>> very few. PLEASE post a step by step guide as to how to get it up and
>>>> running and how to make datasources and layers from it. Either it just
>>>> plain
>>>> doesn't work for me, or I'm doing something wrong repeatedly. I NEED to
>>>> get
>>>> rasters working again - which died after I "upgraded" to MGOS 2.0 from
>>>> 1.0.2. Is there a way to make the old Autodesk raster provider work
>>>> with
>>>> 2.0? This really needs to get fixed....raster support is pretty
>>>> critical.
>>>> Andrew
>>>> *Andrew DeMerchant*
>>>> *Computer Technologist*
>>>> ph.1-877-2GEMTEC x.163
>>>> fax 506-453-9470
>>>> *GEMTEC Limited <http://www.gemtec.ca>
>>>> *191 Doak Road
>>>> Fredericton, NB, Canada
>>>> E3C 2E6
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/raster-help---seriously....-tp17492480p17518764.html
