[ZS1] Re: [mapguide-users] [ZS1] Re: raster help - seriously....
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed May 28 16:04:22 EDT 2008
There are some notes on how to debug Rasters here:
http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
I'm not sure, but you should be able to use the latest FDO package.
You might be able to see the images if you create a map and enter the
correct coordinate extent.
It may also be required to set up a coordinate system override.
Where do you see the "Autodesk.Rasters" message?
Can you try to describe what you try, when concluding that they do not work?
Regards, Kenneth Skovhede, GEOGRAF A/S
mrsyer skrev:
> The data connection works except when i preview my layer nothing is visible?
> I originally installed 2.0.0, but then had some problems so i uninstalled
> it. And by that time 2.0.1 was released so im running that. the plugins im
> using are from the post in this thread, and they are for 2.0.0 could that be
> an issue? thanks.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> If you get that message, your feature source is using the Autodesk
>> raster provider.
>> If you have MapGuide Enterprise 2009, you should re-install it.
>> If you upgrade FDO, be carefull not to overwrite the providers.xml file.
>> If you do not have MapGuide Enterprise 2009, but MapGuide Open Source
>> 2.0.0,
>> you have to create the layer without load procedures. (I assume you are
>> using MapGuide Studio).
>> Select "New dataconnection" and select the GDAL provider.
>> In the dialog, enter the full path to the raster file/folder (try a
>> local path before a network path).
>> mrsyer skrev:
>>> hmmm, Ive tried all of these procedures and nothing seems to work. I
>>> still
>>> get a 'Server does not support file type: Autodesk.Raster' .... Any other
>>> solutions?
>>> Rock Beans wrote:
>>>> Did you try removing any ending slashes from your Raster Path feature
>>>> source? That fixed most of my issues.
>>>> Example:
>>>> C\Rasters\ <-- Broken in 2.0
>>>> C:\Rasters
>>>> The Rock
>>>> On Tue, May 27, 2008 at 9:59 AM, Andrew DeMerchant <
>>>> andrew.demerchant at gemtec.ca> wrote:
>>>>>  Ok, I've asked before - but gotten either no response, or no working
>>>>> solution.....can someone please help get raster working for me? From
>>>>> what
>>>>> I
>>>>> hear, the GDAL works for some people in MGOS 2.0 - though it seems to
>>>>> be
>>>>> very few. PLEASE post a step by step guide as to how to get it up and
>>>>> running and how to make datasources and layers from it. Either it just
>>>>> plain
>>>>> doesn't work for me, or I'm doing something wrong repeatedly. I NEED to
>>>>> get
>>>>> rasters working again - which died after I "upgraded" to MGOS 2.0 from
>>>>> 1.0.2. Is there a way to make the old Autodesk raster provider work
>>>>> with
>>>>> 2.0? This really needs to get fixed....raster support is pretty
>>>>> critical.
>>>>> Andrew
>>>>>     *Andrew DeMerchant*
>>>>>  *Computer Technologist*
>>>>> ph.1-877-2GEMTEC x.163
>>>>> fax 506-453-9470
>>>>> *GEMTEC Limited <http://www.gemtec.ca>
>>>>> *191 Doak Road
>>>>> Fredericton, NB, Canada
>>>>>  E3C 2E6
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080528/28ef9dd5/attachment.html
