[mapguide-users] [ZS1] Re: [ZS1] Re: raster help - seriously....
mrsyer
joey_syer at hotmail.com
Thu May 29 08:34:04 EDT 2008
Well I get the "Autodesk.Rasters" error message when i try to load the data
through a load procedures, but now i realize that loading the image isn't
possible that way.
So thats not an issue now. I have tried both the procedure on the page you
referred as well as the one earlier in this thread. So I have been going
file-new data connection and I believe it succesfully loaded the data.
However, when I go new layer and choose the data connection i created it
doesnt show the photo at all? And i have tried going to the coordinates in a
map but nothing there either. thanks in advance. JS.
Kenneth Skovhede, GEOGRAF A/S wrote:
> There are some notes on how to debug Rasters here:
> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
> I'm not sure, but you should be able to use the latest FDO package.
> You might be able to see the images if you create a map and enter the
> correct coordinate extent.
> It may also be required to set up a coordinate system override.
> Where do you see the "Autodesk.Rasters" message?
> Can you try to describe what you try, when concluding that they do not
> work?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> mrsyer skrev:
>> The data connection works except when i preview my layer nothing is
>> visible?
>> I originally installed 2.0.0, but then had some problems so i uninstalled
>> it. And by that time 2.0.1 was released so im running that. the plugins
>> im
>> using are from the post in this thread, and they are for 2.0.0 could that
>> be
>> an issue? thanks.
>>> If you get that message, your feature source is using the Autodesk
>>> raster provider.
>>> If you have MapGuide Enterprise 2009, you should re-install it.
>>> If you upgrade FDO, be carefull not to overwrite the providers.xml file.
>>> If you do not have MapGuide Enterprise 2009, but MapGuide Open Source
>>> 2.0.0,
>>> you have to create the layer without load procedures. (I assume you are
>>> using MapGuide Studio).
>>> Select "New dataconnection" and select the GDAL provider.
>>> In the dialog, enter the full path to the raster file/folder (try a
>>> local path before a network path).
>>> mrsyer skrev:
>>>> hmmm, Ive tried all of these procedures and nothing seems to work. I
>>>> still
>>>> get a 'Server does not support file type: Autodesk.Raster' .... Any
>>>> other
>>>> solutions?
>>>> Rock Beans wrote:
>>>>> Did you try removing any ending slashes from your Raster Path feature
>>>>> source? That fixed most of my issues.
>>>>> Example:
>>>>> C\Rasters\ <-- Broken in 2.0
>>>>> C:\Rasters
>>>>> The Rock
>>>>> On Tue, May 27, 2008 at 9:59 AM, Andrew DeMerchant <
>>>>> andrew.demerchant at gemtec.ca> wrote:
>>>>>> Ok, I've asked before - but gotten either no response, or no working
>>>>>> solution.....can someone please help get raster working for me? From
>>>>>> what
>>>>>> I
>>>>>> hear, the GDAL works for some people in MGOS 2.0 - though it seems to
>>>>>> be
>>>>>> very few. PLEASE post a step by step guide as to how to get it up and
>>>>>> running and how to make datasources and layers from it. Either it
>>>>>> just
>>>>>> plain
>>>>>> doesn't work for me, or I'm doing something wrong repeatedly. I NEED
>>>>>> to
>>>>>> get
>>>>>> rasters working again - which died after I "upgraded" to MGOS 2.0
>>>>>> from
>>>>>> 1.0.2. Is there a way to make the old Autodesk raster provider work
>>>>>> with
>>>>>> 2.0? This really needs to get fixed....raster support is pretty
>>>>>> critical.
>>>>>> Andrew
>>>>>> *Andrew DeMerchant*
>>>>>> *Computer Technologist*
>>>>>> ph.1-877-2GEMTEC x.163
>>>>>> fax 506-453-9470
>>>>>> *GEMTEC Limited <http://www.gemtec.ca>
>>>>>> *191 Doak Road
>>>>>> Fredericton, NB, Canada
>>>>>> E3C 2E6
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/raster-help---seriously....-tp17492480p17534722.html
