[ZS1] Re: [mapguide-users] [ZS1] Re: [ZS1] Re: raster help -
seriously....
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu May 29 09:00:31 EDT 2008
I can't give you more advice, based on your information.
You must try to follow the guide for debugging (bottom of the page):
http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
The output should give you an idea of the problem, coordinate system,
file access, file format, etc.
If you don't have any idea what the output means, try posting it on the
list, and I'm sure someone else knows.
There are also a few unresolved issues relating to Gdal, links are at
the bottom of the page.
I have seen the Gdal provider report "OK" to "Test connection", even
though it does not accept the files.
Regards, Kenneth Skovhede, GEOGRAF A/S
mrsyer skrev:
> Well I get the "Autodesk.Rasters" error message when i try to load the data
> through a load procedures, but now i realize that loading the image isn't
> possible that way.
> So thats not an issue now. I have tried both the procedure on the page you
> referred as well as the one earlier in this thread. So I have been going
> file-new data connection and I believe it succesfully loaded the data.
> However, when I go new layer and choose the data connection i created it
> doesnt show the photo at all? And i have tried going to the coordinates in a
> map but nothing there either. thanks in advance. JS.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> There are some notes on how to debug Rasters here:
>> I'm not sure, but you should be able to use the latest FDO package.
>> You might be able to see the images if you create a map and enter the
>> correct coordinate extent.
>> It may also be required to set up a coordinate system override.
>> Where do you see the "Autodesk.Rasters" message?
>> Can you try to describe what you try, when concluding that they do not
>> work?
>> mrsyer skrev:
>>> The data connection works except when i preview my layer nothing is
>>> visible?
>>> I originally installed 2.0.0, but then had some problems so i uninstalled
>>> it. And by that time 2.0.1 was released so im running that. the plugins
>>> im
>>> using are from the post in this thread, and they are for 2.0.0 could that
>>> be
>>> an issue? thanks.
>>>> If you get that message, your feature source is using the Autodesk
>>>> raster provider.
>>>> If you have MapGuide Enterprise 2009, you should re-install it.
>>>> If you upgrade FDO, be carefull not to overwrite the providers.xml file.
>>>> If you do not have MapGuide Enterprise 2009, but MapGuide Open Source
>>>> 2.0.0,
>>>> you have to create the layer without load procedures. (I assume you are
>>>> using MapGuide Studio).
>>>> Select "New dataconnection" and select the GDAL provider.
>>>> In the dialog, enter the full path to the raster file/folder (try a
>>>> local path before a network path).
>>>> mrsyer skrev:
>>>>> hmmm, Ive tried all of these procedures and nothing seems to work. I
>>>>> still
>>>>> get a 'Server does not support file type: Autodesk.Raster' .... Any
>>>>> other
>>>>> solutions?
>>>>> Rock Beans wrote:
>>>>>> Did you try removing any ending slashes from your Raster Path feature
>>>>>> source? That fixed most of my issues.
>>>>>> Example:
>>>>>> C\Rasters\ <-- Broken in 2.0
>>>>>> C:\Rasters
>>>>>> The Rock
>>>>>> On Tue, May 27, 2008 at 9:59 AM, Andrew DeMerchant <
>>>>>> andrew.demerchant at gemtec.ca> wrote:
>>>>>>> Ok, I've asked before - but gotten either no response, or no working
>>>>>>> solution.....can someone please help get raster working for me? From
>>>>>>> what
>>>>>>> I
>>>>>>> hear, the GDAL works for some people in MGOS 2.0 - though it seems to
>>>>>>> be
>>>>>>> very few. PLEASE post a step by step guide as to how to get it up and
>>>>>>> running and how to make datasources and layers from it. Either it
>>>>>>> just
>>>>>>> plain
>>>>>>> doesn't work for me, or I'm doing something wrong repeatedly. I NEED
>>>>>>> to
>>>>>>> get
>>>>>>> rasters working again - which died after I "upgraded" to MGOS 2.0
>>>>>>> from
>>>>>>> 1.0.2. Is there a way to make the old Autodesk raster provider work
>>>>>>> with
>>>>>>> 2.0? This really needs to get fixed....raster support is pretty
>>>>>>> critical.
>>>>>>> Andrew
>>>>>>> *Andrew DeMerchant*
>>>>>>> *Computer Technologist*
>>>>>>> ph.1-877-2GEMTEC x.163
>>>>>>> fax 506-453-9470
>>>>>>> *GEMTEC Limited <http://www.gemtec.ca>
>>>>>>> *191 Doak Road
>>>>>>> Fredericton, NB, Canada
>>>>>>> E3C 2E6
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080529/8c183fc5/attachment.html
