[mapguide-users] Niewbie - need some general info on MGOS
Danas Augutis dumas65 at gmail.com
Thu May 29 08:36:22 EDT 2008
Thanks for fast response!
I read carefully links you send to me. Again I have some questions.
1. Is FDO installed together with MGOS extension, or I should I do that
manually?
2. All me data is in Esri geodatabases and in shp'es. According documentation
FDO does not suport rasters in AcrSDE. Is there anyway to add rasters to
MGOS? I have about 1Tb of areal photos is it possible to publish it via MGOS?
3. I was unable to find anything in Getting started guide.Did you mean
http://mapguide.osgeo.org/sites/mapguide.osgeo.org/files/GettingStarted.pdf ?
Regards,
Dumas
On Thursday 29 May 2008 14:36:57 Kenneth Skovhede, GEOGRAF A/S wrote:
> Welcome to the project :)
> 1. It supports many spatial formats, not only databases, through Feature
> Data Objects:
> http://fdo.osgeo.org/
> A list of providers can be found here:
> http://fdo.osgeo.org/OSProviderOverviews.html
> 2. It uses an internal DbXml database to store data that is not spatial.
> It is located in the repository folder, but you should not modify it
> manually.
> You might have heard talk of the SDF format, which is a database like
> format for spatial data.
> 3. Yes! There are 3 different ones, they are listed in the "Getting
> started with MapGuide" guide on page 3:
> http://mapguide.osgeo.org/2.0/documentation.html
> 4. There are error reports for Firefox 3:
> http://trac.osgeo.org/mapguide/search?q=Firefox+3&noquickjump=1&ticket=on&c
>hangeset=on&wiki=on If your problem does not match on of the described ones,
> please create a ticket for it.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Danas Augutis skrev:
> > Hi everybody!
> > I'm was working with ESRI familiar products, but now trying to move to
> > open source.
> > Today I installed mapguide open source on my machine. Everything went
> > fine. But getting started guide is not so good. I have folloving
> > questions: 1. What data (database) formats MGOS does support?
> > 2. I read that it has native database, where it is located?
> > 3. Is there any hot-to help to load raster datasets, or vector data to
> > program?
> > 4. I'm trying to look to examples from
> > http://mapguide.osgeo.org/livegallery.html but insted of layer color I
> > get ? - is there any problem with me broser (firefox 3 b5)?
> > Thanks,
> > Dumas
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
