[mapguide-users] Niewbie - need some general info on MGOS
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu May 29 08:46:05 EDT 2008
1. Yes. If you use MGOS 2.0.1, it should have the latests FDO providers.
MGOS 2.0.0 is missing some providers, you must add manually.
2. There are specific providers for ArcSDE as well as SHP. The OGR
provider also supports those formats.
As for your rasters, the GDAL provider supports many raster formats,
maybe yours too:
http://fdo.osgeo.org/fdogdal/index.html
A short guide for rastes can be found here:
http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
3. Yes, page 3:
MapGuide Open Source (now MapGuide Maestro), WebStudio and Autodesk
MapGuide Studio.
Regards, Kenneth Skovhede, GEOGRAF A/S
Danas Augutis skrev:
> Thanks for fast response!
> I read carefully links you send to me. Again I have some questions.
> 1. Is FDO installed together with MGOS extension, or I should I do that
> manually?
> 2. All me data is in Esri geodatabases and in shp'es. According documentation
> FDO does not suport rasters in AcrSDE. Is there anyway to add rasters to
> MGOS? I have about 1Tb of areal photos is it possible to publish it via MGOS?
> 3. I was unable to find anything in Getting started guide.Did you mean
> http://mapguide.osgeo.org/sites/mapguide.osgeo.org/files/GettingStarted.pdf ?
> Regards,
> Dumas
> On Thursday 29 May 2008 14:36:57 Kenneth Skovhede, GEOGRAF A/S wrote:
>> Welcome to the project :)
>> 1. It supports many spatial formats, not only databases, through Feature
>> Data Objects:
>> A list of providers can be found here:
>> http://fdo.osgeo.org/OSProviderOverviews.html
>> 2. It uses an internal DbXml database to store data that is not spatial.
>> It is located in the repository folder, but you should not modify it
>> manually.
>> You might have heard talk of the SDF format, which is a database like
>> format for spatial data.
>> 3. Yes! There are 3 different ones, they are listed in the "Getting
>> started with MapGuide" guide on page 3:
>> http://mapguide.osgeo.org/2.0/documentation.html
>> 4. There are error reports for Firefox 3:
>> http://trac.osgeo.org/mapguide/search?q=Firefox+3&noquickjump=1&ticket=on&c
>> hangeset=on&wiki=on If your problem does not match on of the described ones,
>> please create a ticket for it.
>>> Hi everybody!
>>> I'm was working with ESRI familiar products, but now trying to move to
>>> open source.
>>> Today I installed mapguide open source on my machine. Everything went
>>> fine. But getting started guide is not so good. I have folloving
>>> questions: 1. What data (database) formats MGOS does support?
>>> 2. I read that it has native database, where it is located?
>>> 3. Is there any hot-to help to load raster datasets, or vector data to
>>> program?
>>> 4. I'm trying to look to examples from
>>> http://mapguide.osgeo.org/livegallery.html but insted of layer color I
>>> get ? - is there any problem with me broser (firefox 3 b5)?
>>> Thanks,
>>> Dumas
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080529/53857e52/attachment.html
