[mapguide-users] VMWare, MGOS and Windows XP SP2
Zac Spitzer
zac.spitzer at gmail.com
Fri May 30 00:04:21 EDT 2008
mapguide does default to using 127.0.0.1 as an ip address, check to see what
the webconfig.ini has for
[SiteConnectionProperties]
IpAddress =127.0.0.1
try using the actual ip....
you can also run fiddler to see what the http traffic looks like
On Fri, May 30, 2008 at 3:49 AM, BenoitBegin <bbegin at geomapgis.ca> wrote:
> Yes, I should've mentionned we did that adsutil MaxConnection trick. We do
> that on pretty much any XP machine we configure now. However, even boosted
> to 40, we'll eventually get the Too Many Connection error.
> I do not believe the error in itself is related to the IIS itself. As all of
> the API calls done directly through the Mapguide Agent will work. The Studio
> works flawlessly as well. However, any API calls done through the .NET API
> to Mapguide will fail at the MGSiteConnection::Open call. Which is where the
> problem lies. Eventually, the calls will start getting through and
> everything will work just fine. Wether the call is done from an ASP.NET
> page, or a desktop application or whatever.
> This problem never occurs on any of our non-virtualized OSes. So my guess
> was that there is something different that has to be done with MGOS to work
> well on VMWare.
> Trevor Wekel wrote:
>> This post seems to indicate that it is possible to increase the IIS
>> connection limit on Windows XP. I haven't tried it though.
>> http://www.codinghorror.com/blog/archives/000329.html
>> Trevor
>> -----Original Message-----
>> From: Andy Morsell [mailto:amorsell at spatialgis.com]
>> Sent: Thursday, May 29, 2008 9:55 AM
>> To: 'MapGuide Users Mail List'
>> Subject: RE: [mapguide-users] VMWare, MGOS and Windows XP SP2
>> Yeah, I'm with you on that. Apache is so much easier to configure and get
>> things working. Unfortunately it doesn't help us when customers require
>> that development be done in .NET.....
>> Andy
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Martin
>> Morrison
>> Sent: Thursday, May 29, 2008 8:10 AM
>> To: MapGuide Users Mail List
>> Subject: RE: SPAM-LOW: [mapguide-users] VMWare, MGOS and Windows XP SP2
>> I just want to note that there is a better fix...use Apache...
>> <G>
>> Martin
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
>> Sent: Thursday, May 29, 2008 11:06 AM
>> Your "too many connections" problem is a limitation of IIS on XP. There
>> is
>> some information here on how to override it.
>> http://wiki.osgeo.org/wiki/MapGuide_Open_User_Technical_FAQ%27s
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> http://www.SpatialGIS.com
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of BenoitBegin
>> Sent: Thursday, May 29, 2008 5:45 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: SPAM-LOW: [mapguide-users] VMWare, MGOS and Windows XP SP2
>> Hi,
>> We've been trying to setup test environments and demo environments using
>> VMWare and Mapguide OpenSource 1.2 (going to move up to 2.0 shortly
>> however). For some reason that is beyond me, we cannot seem to get MGOS to
>> function properly.
>> After the VM is booted up and in Windows XP SP2, if we try to open either
>> the AJAX Viewer or any custom pages that uses MGSite::Open(...), it will
>> throw an Exception saying "Cannot Establish Connection". However, if we
>> can
>> use the Mapguide Studio properly... saving resources, etc etc. We can even
>> go in the MapAgent test page and call any commands, like CreateSession and
>> the likes. It all works fine. It really does seem as if the problem is at
>> the .NET API level, where anything that goes through that API will crash
>> and
>> burn.
>> If we keep hitting the AJAX Viewer with attempts, eventually IIS will spit
>> out a "Too many connections" error. If we run an IIS reset after that
>> error
>> and return to the AJAX Viewer, or our custom pages, they will run without
>> any problems or connection exceptions.
>> We've built quite a bit of sites using both MGOS and MGE without these
>> kinds
>> of issues. They only seem to crop up using VMWare. Is there anything
>> specific to VM that needs to be setup, either at the VMWare level or
>> Mapguide level, to make them work properly?
>> Thanks!
>> View this message in context:
>> http://www.nabble.com/VMWare%2C-MGOS-and-Windows-XP-SP2-tp17534911p17534
>> 911.
>> html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://www.nabble.com/VMWare%2C-MGOS-and-Windows-XP-SP2-tp17534911p17542022.html
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
