[ZS1] [mapguide-users] Shareable markups
erictsn at cadbeyond.com
Fri May 30 23:16:10 EDT 2008
Dear Kenneth,
Thanks for your reply.
At this moments, I do not have idea why it can't to work! I created the
user called "Markup" and the repository (Markup) has been created
automatically. http://59.188.30.133:81/mapguide2009/phpgenerictasks/ This
is the testing server. I have attached the phpgenerictasks files. Anybody
have idea? Thanks
Regards,
Eric
On Fri, 30 May 2008 15:05:15 +0200, "Kenneth Skovhede, GEOGRAF A/S"
<ks at geograf.dk> wrote:
> I don't have a complete manual, but some pointers.
> The rendering process is this:
> Feature source -> Layer definition -> Runtime Map -> Output
> You have the runtime map, so you have to construct a featuresource and a
> layer for each markup.
> The MapGuide API allows you to create an SDF featuresource without
> manual filesystem access/setup.
> The Shareable markups do this.
> Next step is the layer that reference the featuresource. The GT example
> uses a template, and then substitutes certain values before loading the
> LayerDefinition Xml.
> You can also use a single layer, and add multiple conditions, that will
> save you the trouble of creating featuresources.
> The best solution, depends on what you have to do with the data.
> When you have a layer, you must insert it into the runtime map.
> Finally a refresh must be performed on the client.
> If the markups should be avalible permanently, they must be saved in the
> "Library" repository.
> If the markups is just for immediate display, it can be stored in the
> "Session" repository, and will be automatically deleted once the session
> ends.
> That is the basic procedure for all redlining/markup/overlays tasks.
> If you have a more specific question, please post it :).
> Regards, Kenneth Skovhede, GEOGRAF A/S
> mrsyer skrev:
>> Hey everyone, i've got a map up and working and my boss would like me to
> add
>> shareable markup to it. I've got the data from the site
>> "http://data.mapguide.com/mapguide/gt/index.php" but the instructions
> are
>> pretty vague to me. So if anyone has succesfully added this feature I
> would
>> love to have a better procedure to follow. Thanks in advance, JS.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Type: application/zip
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080531/3f872721/phpgenerictasks.zip
