[ZS1] [mapguide-users] Shareable markups
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Sat May 31 15:03:43 EDT 2008
Hi Eric.
If you can avoid it, please don't attach files, because the mail server
forwards them to everyone on the mail list.
I have not worked with the PHP side, or the GT sample enough to help you.
If you post a specific error message or a list of steps, perhaps someone
else can guide you.
Regards, Kenneth Skovhede, GEOGRAF A/S
erictsn at cadbeyond.com skrev:
> Dear Kenneth,
> Thanks for your reply.
> At this moments, I do not have idea why it can't to work! I created the
> user called "Markup" and the repository (Markup) has been created
> automatically. http://59.188.30.133:81/mapguide2009/phpgenerictasks/ This
> is the testing server. I have attached the phpgenerictasks files. Anybody
> have idea? Thanks
> Regards,
> Eric
> On Fri, 30 May 2008 15:05:15 +0200, "Kenneth Skovhede, GEOGRAF A/S"
> <ks at geograf.dk> wrote:
>> I don't have a complete manual, but some pointers.
>> The rendering process is this:
>> Feature source -> Layer definition -> Runtime Map -> Output
>> You have the runtime map, so you have to construct a featuresource and a
>> layer for each markup.
>> The MapGuide API allows you to create an SDF featuresource without
>> manual filesystem access/setup.
>> The Shareable markups do this.
>> Next step is the layer that reference the featuresource. The GT example
>> uses a template, and then substitutes certain values before loading the
>> LayerDefinition Xml.
>> You can also use a single layer, and add multiple conditions, that will
>> save you the trouble of creating featuresources.
>> The best solution, depends on what you have to do with the data.
>> When you have a layer, you must insert it into the runtime map.
>> Finally a refresh must be performed on the client.
>> If the markups should be avalible permanently, they must be saved in the
>> "Library" repository.
>> If the markups is just for immediate display, it can be stored in the
>> "Session" repository, and will be automatically deleted once the session
>> ends.
>> That is the basic procedure for all redlining/markup/overlays tasks.
>> If you have a more specific question, please post it :).
>> mrsyer skrev:
>>> Hey everyone, i've got a map up and working and my boss would like me to
>> add
>>> shareable markup to it. I've got the data from the site
>>> "http://data.mapguide.com/mapguide/gt/index.php" but the instructions
>> are
>>> pretty vague to me. So if anyone has succesfully added this feature I
>> would
>>> love to have a better procedure to follow. Thanks in advance, JS.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080531/d38604c0/attachment.html
