[mapguide-users] difficulty to publish file raster
Mauricio Villablanca mgvillablanca at yahoo.com
Sat Nov 1 23:57:40 EDT 2008
First of all, in order to publish raster files,  the WMS must be enabled for
all the layers that are passed as parameters to Mapagent. You do this by
changing the poperties of the layers in Mapguide Studio. Second, make sure
you pass the correct parameters, in particular the coordinate system (it
must be the same as the one used by the layers).
alfredo54 wrote:
> I find difficulty to publish file raster from MapGuide Studio to MapGuide
> Open Source. I don't succeed in understanding if it is a problem of format
> file or it needs to directly effect the publication intervening on map
> guides open source. In this case as it needs to proceed?
> :confused::confused:
> a lot of graces
View this message in context: http://n2.nabble.com/difficulty-to-publish-file-raster-tp1319742p1444328.html
