[mapguide-users] How to config the WMS Data/Layer published by
MapGuide and how to set the access way to it?
Mauricio Villablanca
mgvillablanca at yahoo.com
Sun Nov 2 00:01:38 EDT 2008
Make sure you enable the WMS for that layer. In Mapguide Studio, right click
on the layer definition choose Properties, enable the service and set the
bounds. Then send the right parameters to Mapgent (same coordinate system as
the layer and correct bounds).
carls wrote:
> I need to access Mapguide as OverLayer in Openlayers, but there are
> something wrong with it (access denied with XMLHttpRequest.open(......)).
> So I moved to Add WMS Layer published by MapGuide. I tested many times,
> there is always a empty image displayed.
> How to config the WMS Data/Layer published by MapGuide and how to set the
> access way to it?
> Thanks!
View this message in context: http://n2.nabble.com/How-to-config-the-WMS-Data-Layer-published-by-MapGuide-and-how-to-set-the-access-way-to-it--tp1298799p1444342.html
