[mapguide-users] Embed Fusion Layout in html or .aspx page
Dave Wilson dave.wilson at autodesk.com
Mon Nov 3 12:18:57 EST 2008
Is there anything special that needs to be done to allow a fusion layout to be embedded in an html or aspx page? The layout loads, but commands like select within and things always generate a
'Fusion' is null or not an object error.
I'm guessing it has to be a scope problem or frame reference type of issue. With the Net consoles enabled in firebug the failure occurs in the fusion/Mapguide/php/Selection.php script
var map = GetParent().Fusion.getMapByName(mapName);
Any ideas?
Thanks,
Dave
Dave Wilson
GBU CRT, Calgary
Autodesk Canada Inc
Ph: 403.538.3069
Fax: 403.264.1442
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081103/3b90db4d/attachment.html
