[mapguide-users] Embed Fusion Layout in html or .aspx page
Berdel, Brian brian.berdel at mcmtrans.com
Mon Nov 3 16:12:52 EST 2008
Does this sample work for you?
C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\www\fusion\templates\map
guide\standard
Index.html?
The Fusion Layout is basically the ApplicationDefinition.XML file and
that is called by the html or aspx page in the directory.
If you are using a template you can edit the template files as well.
Brian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Monday, November 03, 2008 12:19 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Embed Fusion Layout in html or .aspx page
Is there anything special that needs to be done to allow a fusion layout
to be embedded in an html or aspx page? The layout loads, but commands
like select within and things always generate a
'Fusion' is null or not an object error.
I'm guessing it has to be a scope problem or frame reference type of
issue. With the Net consoles enabled in firebug the failure occurs in
the fusion/Mapguide/php/Selection.php script
var map = GetParent().Fusion.getMapByName(mapName);
Any ideas?
Thanks,
Dave
Dave Wilson
GBU CRT, Calgary
Autodesk Canada Inc
Ph: 403.538.3069
Fax: 403.264.1442
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081103/82eb4d50/attachment.html
