[mapguide-users] ID in SelectionXml
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Nov 4 12:00:23 EST 2008
You might also want this link to the MapGuide Central:
http://ennoble.dreamhosters.com/mapguide-central/
Regards, Kenneth Skovhede, GEOGRAF A/S
Love, Bev (Capita Symonds) skrev:
> Excellent -- just what I was looking for.
> That gets me on the right track. I'll do a hunt in the archive for the
> PHP code, and also book mark the archive, didn't know that existed...
> Thanks,
> Bev
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* 04 November 2008 12:16
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] ID in SelectionXml (was: No header)
> Please see this post:
> http://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg03848.html
> And the post mentioned there:
> http://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg03308.html
> Morning all,
> I'm struggling with, what I imagine is, a simple problem, and would
> appreciate any help or points in the right direction.
> I've been developing a search facility which works within the task
> frame. This has been written within JavaScript, and uses Ajax to query
> the database to get the search results. The idea is that once the
> search results are displayed, the user can then click on a result and
> the map will zoom to that item (again using JavaScript). The problem
> is, is that not all the items that are returned have an easting and
> northing co-ordinate. Some of the items are contained within shape files.
> I figured the easiest way to zoom to an item, was to select it on the
> map, and then zoom into that selection. This is where I hit the
> problem. I'm guessing SetSelectionXML() will be used to add the
> selection to the map, however I'm not too sure on what format the XML
> should take.
> I've used GetSelectionXML to get the XML for a similar item that I
> select, but it contains id's for the layer and the item. However these
> do not match the id's that exist in the shape file. Basically what I
> want to know is how do I generate the correct id's for the layer and
> the items (which I wish to select)??
> Thanks,
> Bev
> This email and any attachment are intended solely for the addressee,
> are strictly confidential and may be legally privileged. If you are
> not the intended recipient any reading, dissemination, copying or any
> other use or reliance is prohibited. If you have received this email
> in error please notify the sender immediately by email and then
> permanently delete the email. Copyright reserved.
> All communications, incoming and outgoing, may be recorded and are
> monitored for legitimate business purposes.
> The security and reliability of email transmission cannot be
> guaranteed. It is the recipient's responsibility to scan this e-mail
> and any attachment for the presence of viruses.
> The Capita Group plc and its subsidiaries ("Capita") exclude all
> liability for any loss or damage whatsoever arising or resulting from
> the receipt, use or transmission of this email.
> Any views or opinions expressed in this email are those of the author
> only.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> This email has been scanned for all viruses by the MessageLabs SkyScan
> service.
> only.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081104/7eaaedf3/attachment.html
