[mapguide-users] HTTP 404 Error In Mapviewer Ajax application
padmini godavarthi godavarthi.padmini at gmail.com
Wed Nov 5 05:25:13 EST 2008
Thanks for ur reply .but while running the dotnetviewersample application we
got an error that
The type or namespace name 'JsonObject' could not be found (are you missing
a using directive or an assembly reference)
iam using .net 2.0 with IIS
I have another problem also
after loading the package successfulluy while running the mapviewer ajax
application (given pdf )
http://localhost/mapguide/mapviewerajax/ajaxviewer.aspx/?WEBLAYOUT=Library%3a%2f%2fSamples%2f%2fSheboygan%2fLayouts%2fSheboyganAsp.WebLayout
(i can say-layouts are all in correct path)
i got an error that
Server Error in '/mapguide' Application.
The resource cannot be found.
Description: HTTP 404. The resource you are looking for (or one of its
dependencies) could have been removed, had its name changed, or is
temporarily unavailable.  Please review the following URL and make sure that
it is spelled correctly.
Requested URL: /mapguide/dotnetviewersample/overview/overviewmain.aspx
Version Information: Microsoft .NET Framework Version:2.0.50727.832; ASP.NET
If anybody Know about this error plz help me
Ivan Milicevic-3 wrote:
> Can you find this file in
> C:\Program
> Files\MapGuideOpenSource2.0\WebServerExtensions\www\dotnetviewersample\o
> verview\overviewmain.aspx
> Let's start from here. If you can't download file from
> http://download.osgeo.org/mapguide/releases/2.0.0/samples/dotnetviewersa
> mple.zip
> And extract it in C:\Program
> Files\MapGuideOpenSource2.0\WebServerExtensions\www folder.
> Try that and let us know is there any progress.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
> godavarthi
> Sent: Tuesday, November 04, 2008 1:27 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] HTTp 404 Error In Mapviewer Ajax
> Hi
> im new to the Mapguide Opensource 2.0.While running the mapguideviewer
> ajax
> application i got the following error.
> If anybody is familiar with this problem plz help me.
> that
> ASP.NET
> Version:2.0.50727.832 .
> http://www.nabble.com/HTTp-404-Error-In-Mapviewer-Ajax-tp20321282p203212
> 82.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/HTTp-404-Error-In-Mapviewer-Ajax-tp20321282p20339185.html
